Old 06-17-2018, 04:46 PM   #1
Clem Clement
Clem Clement's Avatar
Default Speedometer boucing
I've lubed it several times, Checked the cable for kinks. Smoothes out at 52mph??
Old 06-17-2018, 04:56 PM   #2
papanick
Default Re: Speedometer boucing
it should be serviced. it sounds like it is hanging up someplace. papanick
papanick is offline   Reply With Quote
Old 06-17-2018, 04:56 PM   #3
papanick
let me know at [email protected]
Old 06-17-2018, 09:17 PM   #4
Travler
Had the same problems along with a very loud sound while driving...it turned out that it required more than lube... the gear was shot, so we disconnected...now I have to guess how fast I am going!
Travler is offline   Reply With Quote
Old 06-17-2018, 09:25 PM   #5
Clem Clement
sometimes I can hear scuffing. I really don't want to remove the mech. Can I spray something to help?
Old 06-17-2018, 10:36 PM   #6
drolston
drolston's Avatar
Try spraying the full length of the cable housing with Gibbs a few times over several days. That stuff penetrates pretty well.
Old 06-17-2018, 11:46 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Remove the inner cable and soak it in solvent to remove all old lube. Clean the old lube from the ID of cable housing. Relube the inner cable with a mix of light oil and graphite, and reassemble the cable to the speedo head, and turtle.
John
Old 06-18-2018, 05:57 AM   #8
oldskool
oldskool's Avatar
Talking Re: Speedometer boucing
I had a similar problem with my 46 merc, removed the speedo gauge and lubed it with a few drops of oil,there is a small lead plug that needs to be removed to do it,that fixed the problem
oldskool is offline   Reply With Quote
Old 06-18-2018, 10:23 AM   #9
deuce_roadster
deuce_roadster's Avatar
If the cable isn't the problem there is a good chance the bushings in the speedo have worn to the point where the drum that the needle is attached to is contacting the spinning part that makes it work. I forget which side has the magnet but basically there are 2 parts that are very close to each other and when the bushings get worn, they can make contact and the needle will jump. I think this possibility is what the #2 post was probably alluding to.
Old 06-18-2018, 12:23 PM   #10
rotorwrench
rotorwrench's Avatar
I don't know what speedometer you have or for what car but they are mostly all rotating magnet with a drag cup as deuce roadster mentioned. Sometimes lubricating the magnet rotor shaft will do the trick and sometimes it won't. Many of the old Ford types have a way to access the oiler wick for that shaft but not all do. There are folks that rebuild speedometers of all types out there but I don't know who to suggest. It helps to know make & model plus any info about the subcontractor that originally made it can help too. Several companies made them for Ford back in the day.
Old 06-18-2018, 12:26 PM   #11
1931 flamingo
1931 flamingo's Avatar
Send your speedo to papanick and/or contact him for some guidance.
Paul in CT
Old 06-18-2018, 10:57 PM   #12
Frank Miller
Frank Miller's Avatar
I use my GPS for speed
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 06-22-2018, 04:22 PM   #13
papanick
let me know if you like to get it serviced. paanick
