Old 09-12-2016, 07:09 AM   #1
Joe777
Joe777's Avatar
Default 46 Ford 1.5 ton
Sunday was a beautiful day so we thought we would pull the old truck out of the garage. This is the first time in 20 years that it has moved under its own power. Then we just couldn't resist driving around the block a time or 2. What a thrill to experience all the familiar sounds and smells these trucks have. Still have some items to finish but the cab and chassis is almost complete. Next phase is to install a Gar Wood dump body from my parts truck.
Joe777 is offline   Reply With Quote
Old 09-12-2016, 07:18 AM   #2
flathead48
Default Re: 46 Ford 1.5 ton
Nice truck, my dad bought a new one in 46, had a dump box on it. Good luck with it
flathead48 is offline   Reply With Quote
Old 09-12-2016, 08:06 AM   #3
corvette8n
corvette8n's Avatar
Great looking truck, just something about those big trucks, enjoy.
Old 09-12-2016, 09:56 AM   #4
alanwoodieman
AHHH, double clutching, gear grinding, smokey doping smell--it don't get any better than that!! great looking truck!
Old 09-12-2016, 11:57 AM   #5
cmbrucew
cmbrucew's Avatar
Joe
Fine looking truck.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-12-2016, 12:20 PM   #6
GB SISSON
GB SISSON's Avatar
Wow! Awesome job. Are those 8.25 x 20s?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 09-12-2016, 08:33 PM   #7
Joe777
Joe777's Avatar
The rear are 8.25x20's and the front are 7.50x20's.
Old 09-12-2016, 08:37 PM   #8
Joe777
Joe777's Avatar
Ya I have to get the hang of double clutching again.
Old 06-23-2019, 08:44 AM   #9
Joe777
Joe777's Avatar
[ATTACH]IMG_0773.jpg[/ATTACH]
Finally finished the dump bed and got it installed on the truck. I'm really pleased with the way the bed looks on the truck and it makes it ride a little better. Now for some mud flaps and marker lights.
Old 06-23-2019, 08:58 AM   #10
big job
big job's Avatar
get the hang of double clutching? then get the hang of no clutching; listen,
all machines will talk to ya. try driving a late tractor trailer you don't use
the clutch at all.
big job is offline   Reply With Quote
Old 06-23-2019, 09:22 AM   #11
Joe777
Joe777's Avatar
the clutch at all.
Baby steps!
Old 06-23-2019, 04:35 PM   #12
flatford8
flatford8's Avatar
Nice truck!!!.....that’s some serious rubber on the back of it.....I have two dump bodies like that if any ones looking......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 06-23-2019, 07:52 PM   #13
42Ford M-H
42Ford M-H's Avatar
Very cool truck !!! I may be slightly bias
42Ford M-H is offline   Reply With Quote
Old 06-23-2019, 08:44 PM   #14
Joe777
Joe777's Avatar
Thanks guys! I think the 8.25x20's in the rear and the 7.50x20's front give the truck a nice stance.
Mark, are the dump bodies you have made by Gar Wood and do you have the hydraulic cylinders? Mine is leaking around the piston with the bed in the down position.
M-H, nice truck! M-H trucks are way cool.
Old 06-23-2019, 09:20 PM   #15
42Ford M-H
42Ford M-H's Avatar
Have you tried repacking the rope seal?
Old 06-24-2019, 06:42 AM   #16
Joe777
Joe777's Avatar
No I haven't but it is on the "to do" list now. Have you ever done this before?
Old 06-24-2019, 09:02 PM   #17
42Ford M-H
42Ford M-H's Avatar
I did the two input shafts, but not the ram itself. I almost think they are meant to leak just a little.
Old 06-24-2019, 09:12 PM   #18
alanwoodieman
post a picture of the end of the cylinder, there are two types of packing for these cylinders, one is chevron and one is rope, which has been replaced with a Teflon packing. leaking in the down position could be wear on the cylinder--do they leak when raised?
Old 06-24-2019, 10:57 PM   #19
Joe777
Joe777's Avatar
No the piston doesn’t leak when the bed is raised which I thought was odd. I looked at a Gar Wood brochure that has a cutaway pic of my cylinder. It shows a substantial seal on the end of the piston which is probably still in descent shape and able to seal when raising the bed. However, when the bed is down the fluid is now ahead of this seal and leaks past the packing around the piston. This system doesn’t have a separate hyd reservoir. I wonder if I overfilled the cylinder?EAC4E737-58D9-48BD-8C63-4B9AF32C66C6.jpeg
I’ll get a better pic of the end of the hyd cylinder. There is a collar around the piston secured with 2 studs and nuts. I assume this is where the packing is.
Old 06-24-2019, 11:09 PM   #20
Joe777
Joe777's Avatar
Mine leaked about half a pint after I lowered the bed. Had some air bubbles also. I’m wondering if I overfilled the cylinder.
