07-05-2018, 10:46 PM | #1 |
Head Repair
Is there any repair that can be done when the head at the upper hose housing bolt has two cracks? For some reason I am not able to attach a photo?
07-05-2018, 11:54 PM | #2 |
Re: Head Repair
I don't know if the head is thick enough for the method called stitching.
07-06-2018, 12:54 AM | #3 |
Re: Head Repair
I’d expect there to be plenty of standard heads about. Maybe you would be better off to scrap the one you have and replace it.
07-06-2018, 08:14 AM | #4 |
Re: Head Repair
I will know more once I get the head off and have it checked for other cracks.
07-06-2018, 08:35 AM | #5 |
Re: Head Repair
Put the head on a BBQ grill until its good and hot, use cast iron rod and weld it. Leave it on the grill, slowly turning down the heat. Cast iron piston rings work well for welding rod. Check head surface for true afterward.
07-06-2018, 09:28 AM | #6 |
Re: Head Repair
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
07-06-2018, 11:39 AM | #7 |
Re: Head Repair
Iron castings that are cracked at a spot 'open' to the edge can be brazed quite easily. Pre-heat a large area, braze and cool slowly. I have done this on the bottom head surface, and also on the block along the right water-jacket area, no problems but you'll probably need to re-surface the head, or at least check it for flatness.
07-06-2018, 11:58 AM | #8 | |
Re: Head Repair
Charlie Stephens |
