Old 01-18-2019, 11:27 AM   #1
John Stone
John Stone's Avatar
Default Rear Motor Mount Safety Wire
Pictures of original safety wire. It is from a rusty '30 Tudor that the odometer showed 30,000 miles.
John Stone is offline   Reply With Quote
Old 01-18-2019, 12:19 PM   #2
rogerkb1936
rogerkb1936's Avatar
Default Re: Rear Motor Mount Safety Wire
interesting
rogerkb1936 is offline   Reply With Quote
Old 01-18-2019, 02:04 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, I have had several unmolested original A's come thru my shop with the same method of safety wiring. Below is a picture of the late Dave Lopes' Fordor that is touted as the best unrestored original Model-A know to exist. The wiring matches your picture John.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-18-2019, 02:18 PM   #4
kbinde2
kbinde2's Avatar
During my Navy enlistment, I worked on ejection seats/egress systems, that required safety wire on several system components. My QA (Quality Assurance) Inspector would look at a job I had done, count proper turns, direction and over-all appearance, and if not correct, would snip it off and tell me to do it over... when I did my motor mounts his words echoed as I made each turn.!
kbinde2 is offline   Reply With Quote
Old 01-18-2019, 05:57 PM   #5
1931 flamingo
1931 flamingo's Avatar
Worked in the o/haul shop at P&WA, interesting when two guys wiring on the same flange (100+ bolts) and one miscounts and it all has to be redone (wiring 2 bolts together, then 2 more, etc.
Paul in CT
Old 01-18-2019, 06:02 PM   #6
Synchro909
Synchro909's Avatar
That's exactly how I do mine.
Old 01-18-2019, 09:21 PM   #7
31 Vicky
I try to add a twist between the two bolts, it is difficult get in there with wire twist pliers. My thought is to connect something between the two.
A's Always
Dave
31 Vicky is offline   Reply With Quote
Old 01-27-2019, 06:05 AM   #8
fredski53
fredski53's Avatar
It's not the space shuttle! Just drive it!
fredski53 is offline   Reply With Quote
