01-26-2022, 05:17 PM | #1 |
problem with 1934 air cleaner
This happened to day. We put original air cleaner on 34 4 door. first time for original air cleaner. car would not run proper, like choke on -- ran it like flooded -- tried several things-- ended up when air cleaner was removed 34 ran fine ---put air cleaner back on eng would start to die. So I tried a different 34 air cleaner. Ran fine . then we look and see a small plate in inside center of air cleaner that has several 1/4 inch holes . we removed plate and all is good . 34 now runs fine . My guess is this is or was instaled in air cleaners for V-8 60 eng. anyone know for sure ?
01-26-2022, 06:11 PM | #2 | |
Re: problem with 1934 air cleaner
01-26-2022, 06:53 PM | #3 |
Mikes tub did this and it was the felt under the top . Stitched seam came apart and it sucked down choking it .
01-26-2022, 09:49 PM | #4 |
I did not say this was a air cleaner for a 1934 ford V8 60 hp . I meant that did a V8 60 have an air cleaner like a 34 only with this plate to restrict the air flow.
01-26-2022, 10:37 PM | #5 |
Oil Bath Air Cleaner on my 1934 Ford V8. |
01-27-2022, 01:32 AM | #6 |
Lawrie |
01-27-2022, 10:01 AM | #7 |
I see your logic but it is highly illogical for any restriction to be placed on an air cleaner. The engine and carb do all the metering needed.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
