05-26-2011, 06:04 PM | #1 |
Replace torque tube grease seal
Is there an easy way to replace front torque tube grease seal in 35
05-26-2011, 07:12 PM | #2 |
Re: Replace torque tube grease seal
05-28-2011, 07:37 AM | #3 |
For some reason I can't get 19Fordy's posted meassages to come up. I did a quick search and found this one........ https://www.fordbarn.com/forum/showth...be+grease+seal
Maybe there are more on this subject if you do more searching
05-28-2011, 09:59 AM | #4 |
I think it is like the 34 tube (the seals are all the samefor 28 to 48)... if so there is a installation tool at MAC (A4246) to install. To remove it I found that the schedule 40 PVC water plastic 1 1/4 inch pipe fits perfect (Home Depot). Just buy one longer than the tube, slide it in from the differential side and tap it out. It is if the pipe was made for it
Ed olari |
05-28-2011, 02:47 PM | #5 |
05-28-2011, 09:15 PM | #6 |
