08-09-2019, 11:50 AM | #1 |
Lucas No Leak . . .
Has anyone used the Lucas No Leak product with any success stopping minor engine leaks? Curios in OKC.
08-09-2019, 05:46 PM | #2 |
Re: Lucas No Leak . . .
What leaks are you talking about!?
www.whidbeymodelaclub.com |
08-09-2019, 06:28 PM | #3 |
That stuff probbly works by softening old hard neroprene oil seals. The Model A has no oil such seals.
08-09-2019, 09:42 PM | #4 |
The engine leaks that are leaving oil on the concrete. Primarily between the clutch assembly and engine (I think) which I suspect is a main that is leaking some. Last edited by DannL; 08-09-2019 at 09:49 PM. |
08-09-2019, 10:16 PM | #5 |
DannL I would check the main caps especially the rear and center mains. It is probably time to remove a couple of thousands of shims. This worked for my 1931 Coupe. Good Luck
Dansluck |
08-10-2019, 12:06 AM | #6 | |
There is always a little oil weeping out past this "labyrinth", so backyard engineers are continually trying to "improve" the original design (with mixed results!). |
08-10-2019, 12:16 AM | #7 | |
That sounds right. Saw a video this evening where that end cap was shown. |
08-10-2019, 07:19 AM | #8 |
It's kinda like we use to say about our old Harleys..."you can tell when it needs oil when there is not a drip spot where you parked it." Chap
Thread Tools | |
Display Modes | |
