Old 09-12-2018, 01:33 PM   #1
kirkf
kirkf's Avatar
Default 1950 8RT Flywheel Refacing
In the shop manual, they state that the maximum depth of the cut for refacing a flywheel is 0.045 "
However I can't find any reference as to what the thickness is of an uncut flywheel.
My flywheel originally measured at .955"
After resurfacing it is now at .940"
Is this within tolerance or not?
Regards,
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 09-13-2018, 07:59 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: 1950 8RT Flywheel Refacing
I really don't see this as a problem.
Old 09-13-2018, 11:34 AM   #3
Russ/40
Russ/40's Avatar
Ditto, don't worry, it does not become an issue. You won't cut more than what final clutch adjustment compensates for.
Not an issue with single plane flywheels.
Russ/40 is offline   Reply With Quote
Old 09-13-2018, 12:34 PM   #4
supereal
supereal's Avatar
At our shop we only cut enough to make a uniform surface.
supereal is offline   Reply With Quote
Thread Tools
Display Modes
