Old 11-11-2018, 07:54 PM   #1
Anteek29
Anteek29's Avatar
Default 12V Stereo/6V System?
Might want to install a CD stereo in my '55 Vic with the stock 6 volt system.
I know a 6 VDC to 12 VDC inverter will be needed but am concerned about
grounding compatibility? Surely this has already been addressed previously
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 11-11-2018, 08:31 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 12V Stereo/6V System?
You might consider mounting the new CD stereo in the glovebox... isolated from the body of the car and powered thru separate wiring from a mid-sized 12v battery (lawn tractor size?) in a box in the trunk. Charging that battery every week should be sufficient, depending on how much you use it.
The very few 6 to 12 volt converters I've used (admittedly ages ago) seemed to buzz or hum thru the speakers.
If the new unit is also a radio I'm not sure if having the antenna mounted/grounded to the body may or may not affect anything. My first guess is that it doesn't matter.
Old 11-11-2018, 10:27 PM   #3
Anteek29
Anteek29's Avatar
Dennis...yes, my intent was to isolate the stereo unit from the car's metalwork.
Guess my other option is to do the stereo upgrade if I convert the Vic to 12 volt
system.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 11-17-2018, 02:05 PM   #4
poolplayer1
I have a 55 ford station wagon that I converted to a 12v system.That would be an option.I also have a 52 ford customline that I wanted to keep original so I left that one alone with its 6 volt positive ground system.I did not want to put a cd player since cd's are going to be obsolete soon so I put in a small USB player to listen to my oldies.
I installed a small positive ground power inverter to power the usb. The usb does not have the audio power that the cd player has but its loud enough.You can get the inverter (eighter positive or negative ground) from Custom Auto Sound in California.
poolplayer1 is offline   Reply With Quote
Old 11-17-2018, 03:48 PM   #5
dmsfrr
dmsfrr's Avatar
Originally Posted by Anteek29 View Post
. . . if I convert the Vic to 12 volt system.
Here's a link about the 6v to 12v conversion. It was written for T-Birds but 99% of it should be the same.
https://www.ctci.org/gilsgarage/6to12.php
Old 11-17-2018, 09:37 PM   #6
Anteek29
Anteek29's Avatar
I have so many music CDs available. Dmsfrr suggested to use a 12v battery mounted in the trunk to power the stereo. A similar approach might be to mount a Lithium jump charger under the dash as a 12v power source.
Oh well, not on my top priority list at the moment...
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 11-21-2018, 12:00 AM   #7
runmikeyrun
There’s some pretty cheap voltage boosters on amazon that seem to work ok. I bought a two pack to run a 12v motorcycle headlight from the factory 6v magneto. Make sure you get one that’s rated for the current draw of your head unit and then add 20% for safety and longevity of the unit.
runmikeyrun is offline   Reply With Quote
