Old 03-13-2020, 07:39 PM   #1
Jim in Wisconsin
Default speedometer gearing
The rear axle in my 33 has "11 - 39" stamped on the flange - a ratio of 3.54 to 1. I replaced the axle many years ago and I think the original was 4.11. (I wonder what the heck I did with that unit? Lost in the shuffle I guess).
My speedometer "turtle" has 18 teeth which I think is not right - it's probably the one from the 4.11 axle. It looks to me like I would need about 21 teeth to get it right.
I've never seen these things advertised as being available - actually it seems like it would be hard to get that large a gear in that turtle anyway.
Any ideas would be appreciated.
Thanks
Jim S.
Jim in Wisconsin is offline   Reply With Quote
Old 03-13-2020, 08:43 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: speedometer gearing
18 tooth is listed in the parts book as for 3:54 ----and lists tire sizes applicable
22 tooth is listed for a lot of 4:11 rears depending on tires
Kurt in NJ is online now   Reply With Quote
Old 03-14-2020, 11:36 AM   #3
Jim in Wisconsin
thanks Kurt, it does look like the 18 tooth is supposed to be right. My speedometer sure seems to register too low, something else must be wrong.
Old 03-14-2020, 12:55 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
to check the gearing keep track of miles against gps, or mile markers ---this way you know if gearing or speedometer is off ---
Old 03-15-2020, 09:35 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
I have 3.54 gears in my '35 fordor and I'm using a turtle with #18, and it definitely has and 18 tooth gear. Tires are 600x16's. The speedo and odometer are deadnuts on per my two gps's.
If you definitely have an 18 tooth turtle, then I'm thinking your speedo head is causing your problem, or maybe too much friction in your cable.
John
