11-28-2010, 02:02 AM | #1 |
40 Ford Spark retard
I read somewhere that if the spark retard is set wrong that it could heat up the engine. Is there any truth to this? I have the helmet distributor. Any advice will be appreciated.
11-28-2010, 02:23 AM | #2 |
Re: 40 Ford Spark retard
Are you sure you have ALL 11-A parts in your dist. EI shaft,adv.weights,adv.plate.Timing should be set on middle mark or maybe1 line up.Vacume plunger almost all the way out?? Diff yr parts will fit in there but will not work as intended. ken ct.
11-28-2010, 07:02 AM | #3 |
To answer your question---YES, improperly timed spark can produce undesirable performance problems, including excess heat entering the cooling system. For a more thorough explanation of how and why that happens, I suggest you read my book.
11-28-2010, 11:39 AM | #4 |
Thanks for the info. I bought the dist. from Mac's. Hopefully everything in it is correct. Since I put it on the car has run hotter than when I had the old one on. I do think the vac plunger is not set correct. I will check the timing mark. I appreciate the info. I am not a mecanic. I am just trail and erroring my way through.
11-28-2010, 11:41 AM | #5 |
What is the name of it and where can I get it. I am new at this so I need all the help I can get.
11-28-2010, 11:58 AM | #6 |
Thanks for your interest, JWL |
11-28-2010, 12:11 PM | #7 |
Here are books for your car you might want to check out:
http://macsautoparts.com/search.asp?...anual&x=9&y=12
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 11-28-2010 at 12:36 PM. |
11-28-2010, 06:47 PM | #8 |
JWL
Please email me the info on the book 01A79 |
11-28-2010, 09:13 PM | #9 |
OK, done.
JWL |
11-28-2010, 11:37 PM | #10 |
I personalty think Johns book is the best one ever written on the Flathead. If everybody had one there wouldn't be a need for these forums.
11-29-2010, 05:52 AM | #11 |
Oh my, I cannot get my hat on. But thanks, Ron.
