08-18-2016, 06:37 AM | #1 |
FS Ignition
Anyone running one of these units in your A? Working well, big improvement etc. How about the centrifugal advance distributor?
Thanks, Steve |
08-18-2016, 06:57 AM | #2 |
Re: FS Ignition
My roadster came with a 12 volt unit and centrifugal advance. Works flawlessly. Quick starts, smooth idle and none of the maintenance associated with a points system. If I had it to do over, would get the Zipper model as it looks like Henrys original distributor.
I Love Anything That Turns Money Into Noise |
08-18-2016, 07:07 AM | #3 |
Re: FS Ignition
Work"s great for me. Had one in my 31 S/W for several years no problems.
08-18-2016, 07:38 AM | #4 |
Re: FS Ignition
ive been running the FS self advance for a few years . set it & forget it . great distributor
V4f |
08-18-2016, 07:57 AM | #5 |
Re: FS Ignition
Works well for me also.
08-18-2016, 08:11 AM | #6 |
Re: FS Ignition
08-18-2016, 08:26 AM | #7 |
Re: FS Ignition
I have the centrifugal advance unit on two cars and it works great on both.
08-18-2016, 09:24 AM | #8 |
Re: FS Ignition
I have a little over 800 miles on my new engine that came equipped with the FS Zipper. Not really sure why I chose the Zipper. While it does look like the original distributor, nothing else under the hood looks original.
So far, no complaints. Just turn the switch and off we go!
08-18-2016, 10:19 AM | #9 |
Re: FS Ignition
For a quick, simple changeover, the Mallory Single Point Dist is hard to beat.
Bill W.
08-18-2016, 10:23 AM | #10 |
Re: FS Ignition
I assume you don't need the spark advance with the Zipper. Do you have to disconnect it from the distributor or can you leave it on so it looks stock?
David Serrano |
08-18-2016, 10:35 AM | #11 |
Re: FS Ignition
You can leave it on but the plate is locked so it doesn't move. I modified mine so I could get a couple degrees retard for climbing hills. I just leave the lever all the way down for normal driving. This is where the timing is set.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
08-18-2016, 11:09 AM | #12 |
Re: FS Ignition
We have the centrifugal advance unit in 3 of our cars. We love them.
Cowtown A's |
08-18-2016, 12:11 PM | #13 |
Re: FS Ignition
"I modified mine so I could get a couple degrees retard for climbing hills"
the centrifugal advance does this automatically
'31 180A |
08-18-2016, 01:56 PM | #14 |
Re: FS Ignition
I gave up on my FS unit and went back to the original system. It now runs better than ever.
08-18-2016, 02:08 PM | #15 |
Re: FS Ignition
I have them in both Model As and both work fine. I do carry a spare module just in case it would go bad on the road. If it does , I can send the bad one back to FS for a free replacement. Good people to buy from.
08-18-2016, 02:38 PM | #16 |
Re: FS Ignition
Bettlesr,
Thanks, David Serrano |
08-18-2016, 03:22 PM | #17 |
Re: FS Ignition
I have the 6V FS ignition with centrifugal advance. Easy start, engine runs great. I can recommend it
Best regards Chris 1930 Ford A Std. Tudor |
08-18-2016, 06:02 PM | #18 | |
Re: FS Ignition
When FS systems first became available over here, the aluminium pieces that goes on the shaft were incorrectly made. It was impossible to time them because the slot had been cut in the wrong place. I've been in touch with them about it and they said that they would replace it but communication (email) stopped when I said I would take them up on the offer.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 08-18-2016 at 08:59 PM. |
08-18-2016, 07:00 PM | #19 |
Re: FS Ignition
that is weird since Mel is such an accommodating person.....more accommodating than most any vendor I have ever dealt with
'31 180A |
08-18-2016, 10:37 PM | #20 | |
Re: FS Ignition
I have to say that reading here about them there seems to be more good then bad.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 08-19-2016 at 11:05 PM. Reason: spelling |
