08-26-2015, 04:15 PM | #1 |
removing throw out bearing lever on transmission
I am attempting to re-build a top loader transmission on my 50 Ford F1 pickup.
I need to remove the throw out lever off the shaft and I have not been able to. Need help, any suggestions? I have drilled a 1/4" hole attempting to drill out the pin but it will still not move. Need suggestions on "how to". could not drive the pin out, so I attempted to drill it out. What size is the pin? Thanks |
08-26-2015, 04:18 PM | #2 |
Re: removing throw out bearing lever on transmission
Isn't the pin tapered and peened over on the small end?
08-26-2015, 05:04 PM | #3 |
The pin IS NOT tapered. They'll usually come out with the use of a pneumatic hammer, and a little patience. DD
08-26-2015, 06:54 PM | #4 |
Yes they are a pain in the arse to remove..
"Came too close to dying to stop living now!" |
08-26-2015, 07:22 PM | #5 |
I did this a couple days ago. I cut the shaft with a zip wheel to get it out then put it in the vise and ground the end of the pin and was able to drive it out.
08-27-2015, 11:42 AM | #6 |
In AdamsFord40 case, I'd heat the pin and then soak for a day or so with Kroil. Also make sure you drilled dead center of the pin. Good Luck, Paul |
08-28-2015, 11:12 AM | #7 |
Thanks for your help. I drilled thru the pin and was able to drive it out. My first transmission re-build. My 50 Ford F1 had a stripped 1st gear. I took the gears out of a 51 side loader and put in the 50 top loader. With loose needle bearings in the 51 had to put in a dummy pin and drive it out with good pin. That's why I had to remove the clutch release shaft. Almost ready to put the transmission back in.
08-28-2015, 11:38 AM | #8 |
Been there, done that! The local True Value sells 3/4" aluminum tubing that I cut to length for the dummy shaft, it fit perfectly.
'52 F-1, EAB flathead |
