Old 03-20-2020, 06:03 PM   #1
Overkill-F1
Overkill-F1's Avatar
Default New Carb Question
The previous owner handed me a remanufactured carburetor when I picked up the truck and I just now compared it to the original one.
There is one item on the base of the new one that I don't know want it is or want it does.
It is the silver item to the right of the idle adjustment screws.
Terry
Overkill-F1 is offline   Reply With Quote
Old 03-20-2020, 06:08 PM   #2
alanwoodieman
Default Re: New Carb Question
that is the later model "power valve location" I think, got a couple of those myself, look on the bowl of the carb and tell us what is there and the one on your carb
Old 03-20-2020, 06:15 PM   #3
tubman
tubman's Avatar
It's not the power valve. Those are still inside the carburetor like the earlier ones. That is what is called a "Spark Valve". I'm not into the later carbs, so I really am not up on what they do or how they do it, but I can assuredly say that it is not interchangeable with a power valve. I think they may have something to do with making the "Load-a-Matic" work better. Just about every 94 rebuild kit you can buy these days contains both one of these and a regular power valve to cover the maximum amount of applications.
Old 03-20-2020, 06:28 PM   #4
Angledrive
Angledrive's Avatar
Denny, this is a good explanation
http://m571.com/yblock/loadomatic.htm
Angledrive is offline   Reply With Quote
Old 03-20-2020, 07:44 PM   #5
scicala
scicala's Avatar
The spark valve was added to the Holley for the Y-Block V8 in '54 (EBU carb). It was also used in '55 and '56 on the Holley two barrel (ECG-5 and ECG-6).
The carb you posted with the spark valve appears to be a '55 or '56 truck carb (1 1/16" venturi) that someone installed an earlier throttle shaft and levers on.
Sal
scicala is offline   Reply With Quote
Old 03-21-2020, 11:11 AM   #6
Overkill-F1
Thank you for the link, this makes me want to replace the "Load-a-Matic" with a converted Chevy dist.
Sal
You are right, cast into the side of the carb is 1 1/16.
Terry
Old 03-21-2020, 12:22 PM   #7
1948F-1Pickup
1948F-1Pickup's Avatar
Tougher to do now without Bubba.
1948F-1Pickup is offline   Reply With Quote
Old 03-21-2020, 01:18 PM   #8
Overkill-F1
Didn't Charlie take over converting chevy dist?
Charlie ny
Be sure to use my e mail....cas5845@yahoo.com
Old 03-21-2020, 01:21 PM   #9
1948F-1Pickup
Charlie ny
Hadn't heard that.....
Old 03-21-2020, 05:00 PM   #10
scicala
scicala's Avatar
I don't know if Charlie ny is helping out Bubba or not, but I know he also does the Chevy distributor to flathead V8 conversions.
Sal
Old 03-21-2020, 05:39 PM   #11
tubman
tubman's Avatar
Actually, all other things being equal, I prefer "Charlie ny"'s conversions because of the "Hold Down" method. It uses a regular stock Ford distributor clamp setup rather than a set screw.
At least that's the way it was a few years ago when I evaluated them.
Old 03-21-2020, 07:28 PM   #12
flatjack9
flatjack9's Avatar
I use Charlie's distributors exclusively. As i understand, he is buying Jim's stock of parts for his use. His are the best.
Old 03-21-2020, 08:28 PM   #13
1948F-1Pickup
That's good to know. I'm thinking of ditching my load-o-matic.
