Old 08-01-2021, 07:51 AM   #1
Mart
Mart's Avatar
Default Mart's 32 Fuel tank and sender. Make 'em work! 2021 Ep31 Pt2
Hello! Welcome to Mart's garage.
Pushing on with the 32 sees me repairing the fuel tank and modifying a suitable sender unit.
Another piece in the Jigsaw.
All the best. I'll catch you on Friday for next weeks update.
Mart.
https://youtu.be/MbkP_SVcEPI
Old 08-01-2021, 11:46 AM   #2
mfirth
Default Re: Mart's 32 Fuel tank and sender. Make 'em work! 2021 Ep31 Pt2
I caoght this on "The HAMB' Mart, but thanks again, still fun stuff.
mfirth is offline   Reply With Quote
Old 08-01-2021, 07:25 PM   #3
koates
Mart, you should have tested the tank unit with the dash gauge you are using on the bench with a battery to see if it all works before fitting to the tank. The original 32 ford fuel gauge was not an electric type. Unless the English cars are different. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-02-2021, 02:32 AM   #4
Mart
Mart's Avatar
Hi Kevin. This was done in conjunction with fitting the gas gauge to the 33. Both gauges were tested with the Pop sender. I used a 6V motorcycle battery during the testing. I'm going to use a novel regulated supply for the 32 and will show it after testing.
thanks for thinking of me.
Mine is a USA 32, but I believe UK ones would be the same hydrostatic unit.
Old 08-02-2021, 01:47 PM   #5
Veeder
As always great video
Veeder is offline   Reply With Quote
Thread Tools
Display Modes
