07-19-2017, 07:36 AM | #1 |
36 gas guage on 12 volts
I just bought a 36 coupe, and the gas guage is not working. Do I need a resistor in line with the sending unit for 12 volt operation?
07-19-2017, 07:38 AM | #2 |
Re: 36 gas guage on 12 volts
No, the current path is through the gauge to the sender and then to ground. There should be a voltage drop added at the input to the gauge.
07-19-2017, 12:34 PM | #3 |
Thanks. There is a resistor in the input line. I tested the circuit, and the sending unit is dead, or has sank to the bottom. The only floats I have are cork, and they are no good, since the alcohal in the gas melts the shelac on the cork, and they then sink. I need to find a modern float before I pull the sending unit out of the tank.
07-19-2017, 01:22 PM | #4 |
You can get original style hollow brass floats from several suppliers I believe. An example for $12. C & G says around $5.
07-19-2017, 03:58 PM | #5 |
I will pull the sender out of the tank and see if it still works, and if not, I see a new one is $35.
07-19-2017, 04:05 PM | #6 |
07-19-2017, 04:31 PM | #7 |
2 many,
A good float from a Ford 94 carb works quite well, it will however require soldering to the arm. Charlie ny |
07-19-2017, 04:49 PM | #8 |
See this thread concerning replacement of the cork float > https://fordbarn.com/forum/showthrea...l+sender+float
