Old 01-17-2014, 01:22 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 36 oil pan removal
Happy New Year Barners! I have a 36 Ford with the stock V8. I noticed some sludge in the oil drain plug and want to drop the pan and clean it. Any tips? Will I have to remove the drag link?
Thanks, Tim
dean333 is offline   Reply With Quote
Old 01-20-2014, 04:19 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 36 oil pan removal
I removed the Sump Pan from my 34 without removing the engine. Firstly, I jacked up the car to give me some movement, then I undid the Radius Rods at the Ball, & pulled them down & put a Packer in to keep them separated. It is still a tight fit, but I managed. While you have it off, remove the Freeze Plugs & clean out the gunk by pushing a Screw Driver or similar up each of the 4 plug holes. You will be amazed at the rubbish that gets trapped in the block, & this is the perfect time to clean it out, as you can't do this with the Sump in Place.
