07-14-2013, 06:08 PM | #1 |
Rotorwrench
The information was very good,on the operation of the fuel sender and fuel gage.I mostly need info on wiring,to test them.I had 6v to bus side of gage.What should other gage terminal be connected to,sender flange?What is the center sender screw wired to?I'm using a 6v lantern battery.I haven't figured out the circuit.Thx.Al.
07-15-2013, 07:28 PM | #2 |
anybody?
need proper connections for fuel sender/gage test circuit.don't want to ruin anything.thx.
07-20-2013, 01:58 PM | #3 |
Re: Rotorwrench
You will need to connect a jumper from the power side of the sender to the battery hot side (negative in a pos ground system). Connect the sender terminal post with a jumper to the sender terminal on the indicator unit. Use another jumper to conect the body of the sender back to the ground post on the battery. |
