12-20-2017, 04:25 PM | #21 |
Re: Newbie needs help ...
Lifting a battery is easy with a devise sold at auto parts houses for that application. It is a strap with positive grip ends that grip the posts. I have 2 of them and glad they are so handy.
12-20-2017, 04:46 PM | #22 | |
Dave, Good luck! However, Mod. A "Popout" ign. switches are known to short internally and drain the system. Don't ask me how I know! A good solution is the switch that Snyders sells for about $55. You lose the "pop out" part of it, but it's a good solid, seems to be well made switch, that won't let you down.
For me, the way I found out the old switch was bad, was just wiggle the key in the switch in the off position, don't turn it!, just wiggle it and keep your eye on the ammeter. If it's bad, you'll see the needle going from zero (Centered) to discharge. These can be rebuilt, but I'm not ready to try it. Quote:
12-20-2017, 05:18 PM | #23 |
I have a lifter more or less like the one in post #21. They work great. The battery is in an awkward place for anybody, whether arthritic or not, and there never seems to be a good place to get a grip on it. They're of course also useful for reinstalling the battery.
12-20-2017, 05:54 PM | #24 |
When the battery reclaimer would pick up dad's old batteries from his store, the guy used an box end wrench! I don't know what size way to many nights since then :-)
12-20-2017, 06:10 PM | #25 |
The battery lifting strap in post #21 makes picking up a battery easy, and they are cheap! Always important to me.
12-20-2017, 06:41 PM | #26 | |
A strap is much better....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
12-21-2017, 04:02 AM | #27 | |
12-21-2017, 11:05 AM | #28 |
You mentioned tackling this in the spring. By all means get the battery up to fully charged before too long. The longer it sits dead the more damage occurs. JMHO
12-21-2017, 03:25 PM | #29 |
Good afternoon...I believe that NAPA still has battery straps that have a clip for the two terminals and then a plastic strap in between. Most likely less than $20.00. Ernie
12-21-2017, 10:06 PM | #30 |
I made my battery lifter with two replacement cable ends and a piece of 1" wratchet. Strap It's works a treat and it's less then the store bought units
12-21-2017, 11:43 PM | #31 |
Dave did you get that running yet ?
