05-26-2017, 06:33 PM | #1 |
No shocks
The shocks on my car need rebuilding or replacing. How bad will my fordor sedan ride with no shocks. The car tends to wonder now. If no shocks make it worse I will leave the car parked until the job is finished.
05-26-2017, 06:43 PM | #2 |
Re: No shocks
Most ANY car with NO SHOCKS is DANGEROUS!!!!!
Bill Rollover
05-26-2017, 06:46 PM | #3 |
Re: No shocks
If they are shot and need rebuilding or replacing, you already know how it will ride when they are not there.
IMHO, a Model A will ride better with new, original style shocks...but maybe not $1,000 better. I don't believe "wandering" has much or anything to do with the shocks. Check steering play all the way through the system. (steering box, king pins, tie rod and drag link ends, alignment, etc.)
All steel from pedal to wheel |
05-26-2017, 07:02 PM | #4 |
Re: No shocks
I am installing MGB shocks on my Tudor. The bolt pattern is exactly the same.
http://www.ebay.com/itm/MGB-MGB-GT-r...3D282487142279
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
05-26-2017, 10:24 PM | #5 |
Re: No shocks
agreed. Shocks will help with bump steer and bouncing but wandering steering on smooth road is worn out steering parts.
1929 Model AA - Need long splash aprons! |
05-27-2017, 07:53 AM | #6 |
Re: No shocks
My car is comfortable driving 50-60 mph, but without shocks it was very uncomfortable at 35-40, hard to keep in the lane |
05-27-2017, 08:39 AM | #7 |
Re: No shocks
Hi Chris. are you doing front or rear shocks?
05-27-2017, 10:28 AM | #8 |
Re: No shocks
My recommendation has always been and will always be the following. Before you think about really driving a 90 year old car, make sure your brakes, front end, steering, springs, and shocks are rebuilt or in a least proper working order. Model A was designed to be driven with quality shocks. That should be the end of the story. Worn out front end, another problem, than on and on. Just because it runs does not mean it is Road worthy.
05-28-2017, 09:22 AM | #9 |
Re: No shocks
We reviewed shocks several years ago and found rebuilt original shocks worked better than the tube shocks. There are several rebuilders of shocks so you can get pricing from various people, we used several and were most pleased with Robert Paul in Colorado. now there are a couple of sources of new original style shocks, Specialty Motor Cams make a great one and Brattons has one that is quite nice too. So you have some options but do put shocks back on for a better ride.
Thread Tools | |
Display Modes | |
