Old 05-25-2017, 02:49 AM   #1
aermotor
Default front wheel hub
End of a long day and went to install a front hub after redoing the kingpins. No matter how much I torqued the axle nut I could not get the hub to "lock" down, even added and extra washer - didn't help. What's going on?
John
aermotor is offline   Reply With Quote
Old 05-25-2017, 05:21 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: front wheel hub
I guess I don't what 'lock' down means. Do the bearings slide all the way on the spindle easily as they should ? The castleated axle nut is used to hold the hub in place and adjust the bearings. You may damage the bearings by tightening them too much.
Old 05-25-2017, 05:52 AM   #3
aermotor
I have always pre-loaded the bearings until the hub would not turn by hand then back off to loosen until they turn easy, then adjust.
John
Old 05-25-2017, 05:57 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I only turn the nut tight enough to know the bearings are in place, then I spin the drum, then loosen the nut and tighten it just enough to remove the slack. This is no tighter than if a 12" adjustable wrench was on the nut in the 3 o'clock position.
Old 05-25-2017, 09:29 AM   #5
Art Newland
Art Newland's Avatar
Are you sure the race is installed?
Art Newland is offline   Reply With Quote
Old 05-25-2017, 10:04 AM   #6
JBill
I've had the same thing happen (for the first time ever) on one side, so I'll be curious about possible explanations.
JBill is offline   Reply With Quote
Old 05-25-2017, 10:30 AM   #7
Big hammer
Are you sure you installed the back bearing? Boy not installed, the hub would wobble like crazy!
get a bigger hammer tap done
Old 05-25-2017, 10:41 AM   #8
H. L. Chauvin
Verification of inside diameter(s) of drum vs. verification of outside diameter(s) of brake shoes may be something to check.
Note the (s) on both diameters .... which translates into inner and outer diameters if drum or shoes are worn more on the outer or inner surfaces.
H. L. Chauvin is offline   Reply With Quote
Old 05-25-2017, 11:38 AM   #9
aermotor
Yes John
Old 05-25-2017, 11:39 AM   #10
aermotor
Yes John
Old 05-25-2017, 11:40 AM   #11
aermotor
Even tried with the shoes off - same thing. John
Old 05-25-2017, 11:58 AM   #12
Patrick L.
Patrick L.'s Avatar
You've answered the other questions, how about my first one ?
Old 05-25-2017, 02:51 PM   #13
aermotor
Problem solved. Wrong bearings and races. The inner bearing was riding on the spindle as it should, however, with the wrong bearing and race the race rode on the grease deflector.
John
Old 05-25-2017, 02:53 PM   #14
aermotor
See post 13
John
Old 05-25-2017, 03:52 PM   #15
Patrick L.
Patrick L.'s Avatar
John
Hmm, I'll be darned. Well, good. At least its fixed.
Old 05-26-2017, 09:04 AM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Wheel bearings are the SAME on Fords & Mercs, clean up to 1948!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-26-2017, 10:23 AM   #17
JBill
See post 13
John
I'll guarantee that wrong bearings and races are not my problem. If it is a problem. I have new cast iron drums with new hubs, and I wonder if the one might have been machined slightly over or under specs.
Thread Tools
Display Modes
