Old 05-26-2017, 04:56 AM   #21
1928closed
Default Re: 1928 gas cap
It does not look ground off, but it's not a rough casting. Where else do I look for a s/n?
1928closed is offline   Reply With Quote
Old 05-26-2017, 07:27 AM   #22
1928closed
picture of blank pad??
Old 05-26-2017, 10:35 AM   #23
Bob C
How about posting some pictures of your truck, may help to date it.
Bob
Old 05-26-2017, 12:10 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, you can see the straight lines where the mill made a few passes to mill off the old number.
I wonder if a needle scaler would roughen it enough to make it look more original?
Old 05-26-2017, 04:26 PM   #25
1928closed
A few older pics, I know I have a 29 steering column, headlights, and fuel tank. Probably can't tell much by the pictures.
Old 05-26-2017, 04:35 PM   #26
1955cj5
1955cj5's Avatar
Were you able to find a s/n on the frame..
Or the date stamp on the fuel tank/firewall?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-26-2017, 04:37 PM   #27
wrndln
You have a 30/31 frame for your 28 pickup. 30/31 front crossmembers and emergency brake shafts are different from 28/29 frames. 28/29 emergency brake shafts mount inside the frame, where as 30/31 shafts go through the frame. 30/31 frames have a lower place where the radiator mounts. You can use a 30/31 frame for a 28/29, but you will need to shim the radiator up some. Also 28 frames had forged runningboard brackets where as 29 - 31 have stamped brackets. However they are interchangeable.
Rusty Nelson
Old 05-26-2017, 06:12 PM   #28
1928closed
Tank is at my shop and I did not make it there today, I'll let you know.
Old 05-26-2017, 06:21 PM   #29
1928closed
Well the plot thickens. I sure do appriciate the input from people who know. My goal is a nice driver so hopefully I can make the chassis work with the 28 body. I guess the 29 parts on the 28 makes sense now since the frame is 30/31. At any rate the truck was complete and assembled when I got it, so this mis-matching must have happened long ago.
Old 05-26-2017, 07:08 PM   #30
CHuDWah
CHuDWah's Avatar
The "square" cab was used 28 to mid-30. The 30 models had the 1/4-turn gas cap (on the 28-29 style tank) and the 30-31 style steering wheel - dunno if the headlights were 28-29 or 30-31. Can't tell for sure from your pic but it looks like the steering wheel might be 30 - the 28-29 is "dished" a bit in the center whereas the 30-31 is flat.
You could have an assembly of parts from different vehicles. OTOH, you have a 30-31 style frame, maybe a 30-31 style steering wheel, and a 29-29 style gas tank with 1/4-turn cap (found ONLY on early-30 trucks AFAIK) - those clues point to an early-30. What makes you think it's a 28? Do you have a title and if so, does it say 28? It could have been changed over the last 77+ years - mistakes can happen when ownership changes and a new title is issued.
WANTED: original flux capacitor and Mr. Fusion Home Energy Reactor. Must be NOS and reasonably priced.
CHuDWah is offline   Reply With Quote
Old 05-26-2017, 07:57 PM   #31
1928closed
Checking the title as I recall it said 1928. So if I have the early 30 tank and that early 30 steering wheel does that mean that the frame is possibly the right frame for this truck or is my frame definitely from a late 30 31 truck?
Old 05-26-2017, 08:35 PM   #32
Tom Wesenberg
From what's been pictured, I'd say your truck was between March and June of 1930.
I don't have my STANDARDS handy, but the parking brake through the frame I think was started about March 1930.
Old 05-26-2017, 08:36 PM   #33
Bob C
The frame, steering wheel and gas tank all say 1930.
Bob
Old 05-26-2017, 08:42 PM   #34
1928closed
So is the frame correct for an early 30?
Old 05-26-2017, 08:52 PM   #35
dlshady
dlshady's Avatar
Agreed, it looks like he's got an early 30 truck. A good friend of mine has an early 30 Deluxe Delivery and it's exactly the same, with the 28/29 style body, 30/31 style frame and steering box, and 28/29 style tank with the 30/31 gas cap.
My latest build thread:
http://fordbarn.com/forum/showthread.php?t=67881
dlshady is offline   Reply With Quote
Old 05-26-2017, 08:53 PM   #36
1928closed
A few more pictures steering wheel and fuel supply tube, which I think is29 or early 30.
Old 05-26-2017, 09:01 PM   #37
1928closed
I just checked and I have stamped running board brackets. 29/30 as everyone is seeming to agree upon. Thanks to all.
