Old 01-27-2015, 10:42 AM   #1
fredski
fredski's Avatar
Default pedal pads where they put on originally
I bought these pads 25 years ago and have not put them on yet.
if I do I will have to boil in water to soften to stretch on.
where these factory installed??
fredski
fredski is offline   Reply With Quote
Old 01-27-2015, 10:56 AM   #2
John Duden
John Duden's Avatar
Default Re: pedal pads where they put on originally
I believe they were accessories, a lot of people put them on.
John Duden is offline   Reply With Quote
Old 01-27-2015, 11:31 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I had a new pair of red pedal pads that I installed on my 29 Tudor. The steel knob on the pedal poked through the red pad within days.
Old 01-27-2015, 11:44 AM   #4
fredski
fredski's Avatar
never really thought pads necessary but will try to install.
they can always be removed .
thanks
Old 01-27-2015, 11:50 AM   #5
Bob C
They were an accessory, A-18422.
Bob
Old 01-27-2015, 12:14 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
Bob
I sure could see them on the VE-28 with the smooth pedals!
That would be something to be researched,...the date when they
were drawn up,....should be in Maffi......
Okay,...I looked...............first date was.....1928-07-28...
d.j. moordigian is offline   Reply With Quote
Old 01-27-2015, 12:38 PM   #7
DougVieyra
DougVieyra's Avatar
As has been said, the rubber pads were not a factory item; they were offered as an accessory, to be put on buy the owner. They do offer quite a bit more 'grab' to the pedal surface, which helps with control of the pedal.
A side benefit is that they protect the metal from wear. And for those who have old original petals, worn smooth by 50 years of wear, the rubber pads both hide the worn pedals and provide renewed grabbing power for the bottom of the driver's shoe.
DougVieyra is offline   Reply With Quote
Old 01-27-2015, 03:05 PM   #8
abachman3
abachman3's Avatar
For those of us in the less than sunny climate, the pedal pads help keep snowy shoes/boots from slipping on the metal pedals.
abachman3 is offline   Reply With Quote
Old 01-27-2015, 03:08 PM   #9
Bill Underwood
Lots of folks use them to cover up wear on the pedals also.
They are a safer alternative than the raw metal. IMHO
But I never use them!!
Bill Underwood is offline   Reply With Quote
Old 01-27-2015, 09:12 PM   #10
KGBnut
KGBnut's Avatar
My pedal were 'slicker than snot' especially with leather-soled dress shoes. I could really only drive in sneakers. The rubber pads significantly improved control. They feel so natural now, I forget they are there.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 01-28-2015, 10:32 AM   #11
Tom Cavallaro
Tom Cavallaro's Avatar
Wow, did not know that.....I find it hard to believe they weren't a factory item....every time your shoes were wet you had to be slipping off!
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 01-28-2015, 10:56 AM   #12
Tom Elliott
For the taller guys you have to lift your legs a little higher to get on the pedals. Might not seem like much but it does make a difference. When related to the Model A being tall isn't always what it's cracked up to be.
Tom Elliott is offline   Reply With Quote
Old 01-28-2015, 11:45 AM   #13
ODFever
ODFever's Avatar
Tom - I know how you feel. I bought a new pair of PF Flyers because the soles on my New Balance shoes were too thick, and made it hard for me to get my size 15 wide on the clutch. I may just take the pedal pad off of the clutch on my '30 Town Sedan to give me a little extra room.
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
