01-21-2018, 05:51 AM | #1 |
29 roadster cowl post picture
anyone have pictures of installing a cowl post, windshield post, and the piece that goes across the top of the gas tank? is there a connecting bracket between the post and the long piece on top of gas tank?
thanks rer_239 |
01-22-2018, 02:23 AM | #2 |
Re: 29 roadster cowl post picture
The cowl posts are riveted to the subframe both at a bottom bracket (3 rivets) and thru the lower outside edge (2 rivets). The cross piece is riveted to the cowl posts on each side (2). There is a bracket on each side that is both riveted to the cowl post and bolted to the fuel tank and through fuel tank edge to the cowl post. Two attaching screws on each end of the dash finish panel also use this same bracket. Here's some pictures - can likely find more of the individual brackets, etc. if they're of any use. Good luck.
01-22-2018, 03:07 AM | #3 |
Great pics Randy, usually all that is broken off or rusted away.
01-22-2018, 05:08 AM | #4 |
thanks |
