Old 05-13-2018, 03:01 PM   #1
Bruce of MN
Bruce of MN's Avatar
Default Front Radius Rod Ball Sockets
My '31 Coupe developed a shudder and it turns out the rubber ball for the rod steel ball had rotted. The steel ball looks good, so I have ordered the stock stamped steel socket kit. With the radius rod hanging, there isn't clearance to remove the old cast upper socket.
Is it OK to force it down just enough to let me slide the old piece off the bolts?
Old 05-13-2018, 03:29 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Front Radius Rod Ball Sockets
yes, just pull it down.
Old 05-13-2018, 05:13 PM   #3
Bruce of MN
Thanks, all it needs is a fraction of an inch.
Old 05-13-2018, 05:49 PM   #4
wrndln
I don't think either of the ball retainers are supposed to be cast. I believe they were stamped. I have several sets that I am pretty sure are original parts and they are stamped. They are like Bratton's PN 4630. Using the original type of radius rod socket retainers might help your problem.
Rusty Nelson
Old 05-13-2018, 06:04 PM   #5
redmodelt
redmodelt's Avatar
He has the rubber ball replacement now. They are cast.
Old 05-13-2018, 07:28 PM   #6
Bruce of MN
Yes, I got that tip from the Snyder's site.
Like my post said, I've ordered the stamped kit.
Old 05-16-2018, 03:05 PM   #7
Bruce of MN
Installed the new socket kit, took it for a test drive around town and no shudder! Thanks to all that helped.
Old 05-16-2018, 03:13 PM   #8
Clem Clement
Clem Clement's Avatar
Yahooooo.com
