06-24-2010, 03:31 PM | #1 |
coil voltage 0n both sides of coil
what is voltage at coil on both pos and neg sides on 6 volt not running and running len
06-24-2010, 03:46 PM | #2 |
Re: coil voltage 0n both sides of coil
6 volts on both sides with the points open, Ign. Switch On or OFF. O volts on Postive side with points closed and Ign. Switch ON. 6 volts always on NEG. side of coil.
I noticed the harder I work the luckier I get! |
06-24-2010, 04:53 PM | #3 |
Tom answered this question on your earlier post. The only real difference between 6v and 12v systems is that a resistor is needed on 12v systems to reduce the voltage to the points..
06-24-2010, 05:10 PM | #4 |
Thread Tools | |
Display Modes | |
