03-24-2020, 09:20 PM | #21 |
Re: Still vibrating but better
original rear end ??? sounds like its floating all over the place any chance of some pics as original would have been torque tube style you need to tie it down some how ie track rods/hairpins/ parallel springs
03-30-2020, 05:57 PM | #22 |
Open driveshaft. I am going to have the DS rebuilt. Angles are right so is the balance but it looks like the ujs are not aligned.
03-30-2020, 06:06 PM | #23 |
You never posted how the rear axle is installed, what supports it?
03-30-2020, 06:10 PM | #24 |
I remember when I put a 67 4 speed in my 59 corvette I had to raise the tail shaft about 1/2 to stop a vibration. JMHO.
12-12-2021, 03:27 PM | #25 |
I'd like to revive this thread. I know this is better suited for the Hamb, but there's a lot of talented people here on the barn that deal with this problem. When I installed the new motor in my car, I had to raise the motor mounts up to clear the oil pan which was modified for main bearing cap supports. That pushed my angle to 3*. I'm not sure what the original degree was, but I don't remember any driveline vibration. Now I need to correct my rear angle by 2.5*. I purchased the proper shims and installed them yesterday. My original reading at the pinion yoke face was .4*. My 35 coupe has a Ford 9" with parallel leafs from Weedetr. After I installed the shims, I put everything back together and dropped the car back down on the wheels. I climbed under to get a reading, and I was getting 5* of angle on the pinion yoke instead of 2.5.
Can someone tell me what I may have done wrong? Thanks |
01-03-2022, 12:12 AM | #26 | |
01-03-2022, 10:01 AM | #27 |
Was the flywheel and clutch balanced?
A man should do what he thinks best! "The Duke" |
