06-23-2020, 01:49 PM | #1 |
1936 LB engine crack
Can this crack be repaired? It goes down in very edge of cylinder 3. I understand a sleeve would be required, it is bored .30 over. No other cracks seen, but has not been pressure tested. Last edited by lotsagas4u; 06-23-2020 at 03:01 PM. |
06-23-2020, 02:21 PM | #2 |
Re: 1936 LB engine crack
Looks like someone has been in there before and tried to weld it.
06-23-2020, 04:15 PM | #3 |
Thatīs probably a crack pin someone put in there.
Pressure test...maybe itīs holding as is...then you can improve enough to make you sleep well at night |
06-23-2020, 04:30 PM | #4 |
