Old 07-28-2013, 01:12 PM   #1
bhiland
Default help
So the wife and I took a drive today in the A and had some trouble. Everything was fine and we had drove several miles. Came to a stop sign and when we took off again we lost power. I looked at ignition switch and the key was turned back just enough to kill it I guess. It has happened before. So I turned they key back on and was fine for a few seconds then BANG backfire! Then crazy engine knock and no power so I killed it and brought it to a stop. Looked all over the engine and didn't see anything out of norm. Let it sit for a few minutes and tried to start it again. It started and knocked for a few and then stopped knocking but have less power and not much oil pressure. I limped it home and now deciding where to start.
bhiland is offline   Reply With Quote
Old 07-28-2013, 02:11 PM   #2
afuncar
Default Re: help
I think you should take a look at dist and timing after that I,d look at timing gear possable oil pump and dist. Drive gear. Good luck
afuncar is offline   Reply With Quote
Old 07-28-2013, 02:53 PM   #3
1crosscut
1crosscut's Avatar
Default Re: help
Probably when the switch turned off you built up unburnt fuel in the muffler causing the back fire. May be possible that you collasped a baffle or two in the muffler and it's causing back pressure and loss of power. Going to be loud but pull the muffler loose from the manifold and see if you gain back your power.
A's don't have very much oil pressure to start with. Mostly they flow a lot of oil with very little pressure. As long as your registering a couple lbs. or so your probably good.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-28-2013, 04:10 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Default Re: help
I would remove the side timing cover, turn the engine over with the starter , with the spark plugs removed. Watch the teeth on the timing gear when it turns. I figure that some teeth will be damaged and missing.. There are two 5/8 bolts on the side and one under the edge of the oil pan, that a 1/2 inch socket will fit. If you are careful the side timing cover can be removed without damage to the oil pan gasket. When the timing gear starts to fail, it will buck and knock and won't run good at all. The cam turns the oil pump, if the cam gear is striping and skiping the oil pump can't function at an optimum level.
Old 07-28-2013, 04:32 PM   #5
bhiland
Default Re: help
Ok ill check all of that also. My coil doesn't have much power now either when I use the tester.
Old 07-28-2013, 06:48 PM   #6
bhiland
Unhappy Re: help
Well I have no compression on #3
Old 07-28-2013, 06:53 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: help
With timing pin in the cam gear dimple, is the rotor pointing at #1 and just ready to open the points? CCW rotation
Old 07-28-2013, 07:16 PM   #8
glenn in camino
glenn in camino's Avatar
Default Re: help
Start by telling your wife that you're sorry, your Model A is sorry and she doesn't have to go on the next ride, unless she wants to. You'll find out how much she loves you. My wife and I have been riding in our Model As since the late 60s. She always takes a good book and now her favorite Model A tool, her cell phone.
Old 07-28-2013, 07:44 PM   #9
bhiland
Default Re: help
Yes its at #1 but I think the points may be a little bit before just opening
Old 07-28-2013, 07:46 PM   #10
bhiland
Default Re: help
She loves the car and all ready said sorry to all involved lol.
Old 07-28-2013, 08:38 PM   #11
bhiland
Default Re: help
I'm wondering if it dropped a valve.
Old 07-28-2013, 09:34 PM   #12
Tom Wesenberg
Default Re: help
Crank the engine so the bad cylinder piston is TDC on firing, then blow compressed air into the spark plug hole. If it has 0 compression, the air will come out the carb (intake valve), or tail pipe (exhaust valve), or oil fill pipe (bad rings or piston).
Old 07-29-2013, 09:14 AM   #13
Will N
Will N's Avatar
Default Re: help
So your problems all started from a backfire due to a bad ignition switch? Whenever someone in our club has problems with their ignintion switch, the first thing we look at is how many keys do they have hanging on their keychain. All that extra weight pulling on those repop switches, which usually do not have a strong detente on either the on or off positions, is the first culprit that we find causing the intermittant switch problems.
Will N is offline   Reply With Quote
Old 07-29-2013, 10:18 AM   #14
Mike V. Florida
Mike V. Florida's Avatar
Default Re: help
Double check the ign switch for reliable operation. An intermittent switch will show all the symptoms you describe.
Old 07-29-2013, 03:33 PM   #15
bhiland
Default Re: help
Piston is moving couldn't get a good look at valves. Piston looks wet and looks like it has some scaring on the head of piston.
Old 07-29-2013, 03:36 PM   #16
bhiland
Default Re: help
Only got ignition key and key for side mount lock on the key ring.
Old 07-29-2013, 03:38 PM   #17
bhiland
Default Re: help
But I have hardly any oil pressure and it was knocking to beat the band for a minute. Ignition switch wouldn't cause that and no compression in #3 cylinder.
Old 07-29-2013, 03:56 PM   #18
Purdy Swoft
Default Re: help
You may have a combination of problems. I had a lot of problems with the low cost ignition switches. The only reason that I didn't mention the switch in post number 4 was because you mention knocks and loss of oil pressure in the original post. You've got a strange combination of symptoms!!
Old 07-29-2013, 04:07 PM   #19
Mike V. Florida
Default Re: help
Please describe your engine, Stock or what? Stock engine only has two or three pounds when warmed up.
Old 07-29-2013, 05:17 PM   #20
bhiland
Default Re: help
Its just a stock engine with stock head.
