Old 03-03-2018, 09:49 AM   #1
Bob from Northport
Bob from Northport's Avatar
Default Brake switch question
We have a vehicle in the shop with no tail lights/brake lights. I have seen photos of the brake switch used on a T. Where/what does it attach to make it work?? 1925 Huckster/Taxi
Thanks!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 03-03-2018, 10:21 AM   #2
39portlander
39portlander's Avatar
Default Re: Brake switch question
Bob, the 3158XS original style stop light switch as Lang's have in their catalog is "a must for show cars, marginal reliability".
They offer a 3158HD brake light switch designed for model T's. This switch is 60 amps that can handle 2 brake lights, 6 or 12 volt it says will work with Rocky Mountain brakes and Ruckstell shifters.
I'm keeping my original if I do restore my 26 but will be using the HD when I hopefully get it running this summer. There are several makers of very nice dual rear brake and turn signals. Let us know how you make out. Scott
39portlander is offline   Reply With Quote
Old 03-03-2018, 12:26 PM   #3
CharlieB
CharlieB's Avatar
Bob if you're starting from scratch check out the Fun Projects brake light kit. Comes with a weather proof switch and a great bracket that fits perfectly. Some additional hardware
included. definitely worth a look. Funprojects.com
CharlieB is offline   Reply With Quote
Old 03-03-2018, 06:03 PM   #4
39portlander
Hey Charlie it looks like Funprojects makes that 3158HD, same place I got my coil tester. Scott
Old 03-04-2018, 09:26 AM   #5
Chad Marchees
The Fun Projects brake light switch is awesome. I have it on two T's and will be getting a third.
As they say, A pic is worth a thousand words.
Chad Marchees is offline   Reply With Quote
Old 03-04-2018, 09:32 AM   #6
Bob from Northport
Thanks for the information and the photo. Very nice!! What is the big black cup on top the universal joint housing for. ?? Is it a lube point??
Bob from Northport
Northport, Michigan
Old 03-04-2018, 10:35 AM   #7
Chad Marchees
Yes, that is grease cup, and the lube point for the universal joint. There should be a smaller grease cup behind it to grease the driveshaft bushing.
Popular mod is to tap them and install zerk fittings for easier, less messy greasing. Once the cap is screwed back on, no one knows that mod was done.
Old 03-05-2018, 09:08 AM   #8
Bob from Northport
Thank You!!
Bob from Northport
Northport, Michigan
