Old 05-17-2016, 07:29 AM   #1
Kurt in NJ
Kurt in NJ's Avatar
Default Running board antenna
I am looking for more about the runningboard antenna used on 36 open cars---the picture in the 35-36 book is small, but it looks like something I can make if I have a little more information, I have seen the "repro" universal one that was or is still made and it is not for me, and I have 2 versions of an aftermarked one that doesn't look as easy to copy with the equipment I have
From the picture it looks to hang somewhat below the frame and I don't think they survived very well, and soon they were out of style---I need to make one for a friends 36 Packard, and he doesn't care if it is the same as the one for my conv sedan
Old 05-17-2016, 07:51 AM   #2
mrtexas
mrtexas's Avatar
Default Re: Running board antenna
I just bought a generic antenna and mounted it below the runningboard. Works great.
mrtexas is offline   Reply With Quote
Old 05-17-2016, 08:44 AM   #3
TJ
TJ's Avatar
I've done the same on 3 cars and they do work great. The generic antenna is also a lot cheaper.
Old 05-17-2016, 08:47 AM   #4
flatheadfan
flatheadfan's Avatar
I couple of things I have done and in both cases has worked well. Note the pictures.
The first is an original running board antenna installed at the dealership (1936). This could be easily made.
The second picture is a "modern" type used on a 1935.
Tom
flatheadfan is offline   Reply With Quote
Old 05-17-2016, 09:06 AM   #5
Joe Immler
When I found my '41 Ford the antenna under the running board was 3 coat hangers tied together. Could only get the high wattage station. The other suggestions will work better I'm guessin.
Joe Immler is offline   Reply With Quote
Old 05-17-2016, 09:33 AM   #6
deuce_roadster
deuce_roadster's Avatar
I have an NOS 33-34 antenna that goes on the spare tire bracket. I don't know if 35-36 had anything similar but it would be out of the mud. If you want a scan of the instruction sheet PM me.
Old 05-17-2016, 10:35 AM   #7
Don Rogers
Don Rogers's Avatar
Kurt, Here are some photos of an original running board antenna. Please note that the mounting directions point out that there was an antenna under each running board.
Don Rogers is offline   Reply With Quote
Old 05-17-2016, 10:51 AM   #8
flatheadfan
Picture with dimensions-
Old 05-17-2016, 11:00 AM   #9
Dave/Green Bay
Is there someone that makes the cable to connect the radio box to the antenna?
Thanks Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
Old 05-17-2016, 04:38 PM   #10
flatheadfan
Dave-
This is the easy part. You need a RCA cable with two male ends, a female plug mount and an "eye" terminal.
Install the female pug in the radio chassis . Use a small wire to connect the female plug to the antenna wire post inside the radio. Solder
Attach the terminal eye to the antenna frame.
Insert the RCA male end of the radio cable into the terminal eye.
Your done!
Tom
Old 05-17-2016, 04:48 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I got the cable for the lead in from Tyree Harris wiring, it has original type end that looks like a small light bulb socket with the 2 pins
Old 05-17-2016, 04:54 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
In looking at the pictures the antenna mounted on the car looks to have rectangular rubber mounting blocks, the antenna parts that are shown off the car the rubber mounts have the ridge around the center--- this is like what I found for the Packard antenna-- perhaps both kinds were used, the innards of the Packard radio are Philco too,
Old 05-17-2016, 05:26 PM   #13
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I have a reguler antenna that you would bolt to side, I mounted under the running board on my 31 Model A coupe, it works fine. Walt
Old 05-17-2016, 07:27 PM   #14
Dave/Green Bay
Tom & Kurt:
Thank you for the information.
Dave
