07-08-2019, 10:55 PM | #1 |
t10 speedo driven gear
Having trouble finding info on which replacement gear to get for my speedo cable. Has anyone run the t10 on a customline? Mine's a 54
07-09-2019, 09:19 PM | #2 |
Re: t10 speedo driven gear
What kind of info. Number of teeth or tooth orientation? There are two Tooth orientations - left and right The only problem is that I cannot remember which is which and if I remember correctly it is determined on what side the gear goes into the trans.
The proper gear is the one that uses the little clip to hold it onto the cable.
07-12-2019, 03:38 PM | #3 |
The speedo driven gear must mesh with the drive gear on the output shaft.
And then you go thru a chart entering axle ratio, tire size, etc. Isn't there something about a later style gear not fitting an early cable housing?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-12-2019, 09:54 PM | #4 |
The later style gear will NOT fit the early cable. Since it's T-10 which came out later than 1957, it uses the later type gear. You must get a cable that matches the speedo and the trans. The stock 54 cable will not. Some Mustang cables will work. Look on ebay (MUstang speedometer cables) and the pictures of the different cables will show you what you need.
As far as the gears, they are fairly cheap and you can get two or three to experiment with. This is what I did with my 48, 54 and 56 Fords.
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 07-12-2019 at 10:05 PM. |
07-21-2019, 09:03 PM | #5 |
Thank you all for your input. Still digging in. Replaced windshield and shocks, and have had a lot of run driving it in it's current state. Just trying to get dash all together and working at this point. then minimal body and paint
07-22-2019, 05:49 AM | #6 |
Call and ask the one URL. You may have to pull your cable to get measurements to replace and/or modify. Will worry about actual gears later. Which side of the tail housing is the cable on? I would like to know the answer also.
07-22-2019, 11:10 AM | #7 |
port for cable is on passenger side of tail housing. Going to hit it with flashlight/inspection camera to see color/count teeth today.
07-22-2019, 11:27 AM | #8 |
While you are under there, see if there is an ID TAG attached still.
It will give you the the correct PARTS LIST to see what drive gear is in there. If no tag, any idea what year/model it came out of?
07-22-2019, 01:46 PM | #9 |
It looks like Drive gear is 7 teeth, on passenger side. rear end is 9 inch with 3.30 tag. From what I have been able to dig up, that means a 16 tooth LH rotation driven gear, right?
07-22-2019, 01:51 PM | #10 |
07-22-2019, 05:59 PM | #11 |
Your image came through broken.
There was no ASSY ID TAG @ the main case/tail shaft capscrew(s)? There is a formula to come to the correct gear(s). You will need REAR GEAR RATIO and tire size dimensions. First the TRANS has to be positively ID'd. Otherwise it is just a guessing game.
07-25-2019, 08:14 AM | #12 | |
Found this info at THE OTHER FORUM.
Here is your out. To wit- Quote:
https://www.speedoservice.com/speedometers.html
07-28-2019, 04:13 PM | #13 |
Thank you, Kultulz. Just sent them an email
07-28-2019, 05:57 PM | #14 |
The make correction ratio drives that can be installed in the cable linkage as well. A person can get the system to be pretty accurate but as soon as the rear tires are changed with something else then the accuracy will likely be off a bit again.
08-05-2019, 03:39 PM | #15 |
Just got off the phone with Rusty at SpeedoService. We figured out a plan, and my sleeve and cable will be made/shipped tomorrow. Thanks again for all the hlp navigating a fairly new world, folks
