Old 07-18-2019, 06:34 PM   #21
dmsfrr
dmsfrr's Avatar
Default Re: 292 312 Ford Engine
Originally Posted by ncauclair View Post
I took a photo of the number on the block below the distributor. ... I tried to post the engine photos here but it won't let me????
The "file size" of the photo has to be less than 2mb, to be able to upload it.
Old 07-18-2019, 08:19 PM   #22
darrell
its a 292 at least maybe 312
darrell is offline   Reply With Quote
Old 07-18-2019, 08:26 PM   #23
darrell
just forget that last one 272 can be dif or cf its 292 and 312 that are cf only.
Old 07-18-2019, 08:26 PM   #24
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
There is a letter/number cast into the side of the block above the oil pan rail. If you see ECZ-xxxx-A or C, there is a good chance it is a 312. The only way for sure is to look on the crank flange for a flat spot with a dot in the center. Then it is a 312. Ford made both 292's and 312's on that same block in the last years of the 312, just machined the main bores to a larger size for 312's. John Mummerts website shows and explains all this in greater detail.
streetdreams is online now   Reply With Quote
Old 07-18-2019, 10:40 PM   #25
dmsfrr
dmsfrr's Avatar
Originally Posted by streetdreams View Post
... The only way for sure is to look on the crank flange for a flat spot with a dot in the center. Then it is a 312. Ford made both 292's and 312's on that same block in the last years of the 312, just machined the main bores to a larger size for 312's. John Mummerts website shows and explains all this in greater detail.
The dot on a 312 crankshaft, as streetdreams mentioned. (photo 1)
Main bearing caps for a 312 have an ECZ prefix casting number. All others are EBU.
Two links to the *ID a 312* pages on John Mummerts website...
http://ford-y-block.com/identify312.htm
http://ford-y-block.com/crankshaftid.htm
Old 07-19-2019, 06:47 AM   #26
ncauclair
I've been trying to post a photo of the engine. But it says my security token is missing? Dumb guy--don't know what that means. The photo isn't large MB?
ncauclair is offline   Reply With Quote
Old 07-19-2019, 10:34 AM   #27
dmsfrr
dmsfrr's Avatar
If you can send the photo to dmsfrr@gmail.com I'll try to post it for you.
But it may a bit... I'm fairly busy today cleaning out a space in the garage for a car I'm leaving town to pick up tomorrow.
Old 07-19-2019, 10:47 AM   #28
40cpe
40cpe's Avatar
Send it to purser2@windstream.net and I can get to it quickly.
Old 07-19-2019, 01:03 PM   #29
40cpe
40cpe's Avatar
here are the pics.They were between 4.5 and 8.5 MB
Old 07-19-2019, 02:07 PM   #30
streetdreams
Still cannot determine engine size. The cross over exhaust is early, but I've seen 312 long blocks under that old exhaust and lifter galley covers.
Old 07-19-2019, 02:13 PM   #31
darrell
didnt know it was a truck engine.from what you can see its a 292 but things could be changed around.
Old 07-19-2019, 03:29 PM   #32
40cpe
40cpe's Avatar
What do you see that leads you to think it is a 292?
Old 07-19-2019, 03:29 PM   #33
ncauclair
thanks for posting the photos-you're more computer savvy than I. I'm listing the engine for sale. What's a fair price? Part it out or as a whole? I live in Greenville VA. I have a couple of Ford trucks a 62 and 64 F 100s. Picked this engine up to put into the 62-- but we ended up rebuilding the one was that in it.
Old 07-19-2019, 03:35 PM   #34
KULTULZ
KULTULZ's Avatar
Post Re: 292 312 Ford Engine
That's going to be hard to determine until the engine is identified.
Where is Greenville, VA?
My Colonoscopy Results Just Came Back. Perfect Score.
Wife Always Calls Me An A$$-Hole And I Just Wanted To Be Perfect For Her.
KULTULZ is offline   Reply With Quote
Old 07-19-2019, 04:25 PM   #35
ncauclair
Near Lexington and Staunton VA off of I 81. In the Shenandoah valley.
Old 07-19-2019, 04:44 PM   #36
scicala
scicala's Avatar
I can take a guess from the pictures, but a block and head casting number would help a lot. Heads are '56 or later. The distributor is '57 or later. Rocker arm adjusting nuts are '57 or later. The front cover has two flat machined bosses on top (I think that's truck ?).
If I guessed, I would say it's a truck 292 from '58 to the early 60's. Plus pretty sure they stopped building 272's after 1957.
Sal
scicala is offline   Reply With Quote
Old 07-19-2019, 04:51 PM   #37
scicala
scicala's Avatar
I stand corrected. The 272 was still available in '58 and possibly '59 in trucks.
Sal
Old 07-19-2019, 05:06 PM   #38
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 292 312 Ford Engine
I should have known that. Born in Roanoke and am now a little above Martinsburg, WV (still trying to figure out how I wound up here in Yankee Country ... ).
Old 07-19-2019, 05:20 PM   #39
darrell
the 272 was used in early 58 and then was upped to 292.scicala pointed out why it should be a 292.the valley cover is 58 or newer.unless someone shifted things around its a 292.if we knew what heads we could figure the year.
Old 07-19-2019, 06:41 PM   #40
KULTULZ
KULTULZ's Avatar
Cool Re: 292 312 Ford Engine
Let's guess the ENGINE ID with just a few picture ...
That engine could be any combination of parts over the service life of the FYB.
It has to be ID'd by the CASTING ID and DATE CODE NOS.
What if the OP tries to sell it using incorrect info and once the buyer puts it on a forensic table finds what it was described as isn't?
I feel like I am watching old I CAME NAME THAT TUNE TV shows ...
