06-23-2019, 06:49 AM | #1 |
F-6 two speed rear won't downshift
My vacuum actuated 2 speed won't downshift when the truck is running. I checked the valve and it has 15 inches of vacuum when in HIGH range, and 0 in low range. I watched the actuator on the rearend and it moves in and out. The truck will be in low range after it sits for a night. Then I shift to HIGH and its fine. But when I try to go back to low I get a loud grinding noise from the driveshaft. Whatever is supposed to mesh in the rear - isn't as far as I can tell. Any ideas on what to try next? I'm a novice on differentials. Never had one apart.
06-23-2019, 08:07 AM | #2 |
Re: F-6 two speed rear won't downshift
Usually a vac leak somewhere between the carb and rear end diaphram. If I remember right, high shifts with a spring and low has to be pulled in or maybe the other way. Anyway the shift valve on the firewall will have only one hose going back to the rear.
06-23-2019, 08:07 AM | #3 |
Sounds like all is fine. Rule 1, if done for the day always park in 'low range' Not in high.
Rule 2, lets say you are cruising in forth and the axle is in high range and hit a hill and you want to shift axle down to low range - now pay attention; you floor the gas pedal and put button in Low ;;;;; now quickly pop the clutch - now you are now in low range, get over the hill and pull the axle button out, let of gas now your into high. simple. Myself I prefer vac over electric its more friendly. For electric you gotta be quick cause they are so quick you loose it, then It goes into la la land (grinding) and you must stop start all over again. So bottom line you must keep pressure on axle gears, then shift, goes for all old or new trucks. So remember pedal to the medal, pop clutch, and bingo you are now in low pull button to high let off gas you now in high range: Your F6 with 2 speed equals 8 speeds and two speeds in reverse. Hope you got it cause I'm no story writer just a truck driver. sam |
06-23-2019, 08:16 AM | #4 | |
new and still doing it....................... |
06-23-2019, 07:42 PM | #5 |
Well, I really don't think its my driving. I drove this all last year and could split shift and downshift on the hills when loaded. This winter I changed the engine and transmission and now I can't downshift the diff. I don't think its a vacuum leak because the way I see it, the the high range is under vacuum and the low range is 0 vacuum and under spring pressure. The reason I think that is because when the engine is off it defaults to 0 vacuum and low range. I watched the actuator when I switched the vacuum on and off and confirmed this. During the engine replacement, I tightened a lot of loose hoses and the threaded connections on the valve and the splitter.
I'm pretty sure something else has gone wrong. I just don't know where else to look. |
06-24-2019, 03:34 AM | #6 |
all in low like in your driveway - if it moves ok in high I should think that rules out a vac.. leak. Almost sounds like the control valve on the fire wall isn't completely exhausting vac from the actuator. Maybe remove the actuator and see if the lever moves smoothly you might have to jack it up turn drive shaft and move the lever. Has to be something simple these axles are pretty rugged. Example of severe vac leak. Have a F6 no high range when I pull the button to high just about stalls the engine so it has a ruptured actuator diaphram. Meanwhile I'll keep thinking ? sam |
06-24-2019, 06:39 PM | #7 |
That's the strange thing. It worked before the engine change.
After the truck sits overnight, It drops back into low range. I can drive it for miles in low range. Works fine. Then I shift up to high range and it works great. The problem is it won't go back to low range no matter what I try. I've done the full throttle thing, I have come to a stop, nothing seems to get it back to low except sitting overnight. I wonder if there is a spring somewhere that is weak and is not forcing the gears back to low range. I hear a lot of grinding when I switch to low and it will not drop in. It used to drop in when I stopped as a last resort, but no more. |
06-25-2019, 08:09 AM | #8 |
Sits overnight then goes into low? that rules out a weak spring and shows it is working.
This is a symptom that the control valve is not releasing ALL the vacuum in the line to the actuator. I would make sure it is in high range secure the truck shut engine off go under there and pull the hose off the actuator should be a good rush of air sound and watch the lever move. Leave the hose off for now. Put the button in low, start truck it should now be in low. This is like imitating "sitting overnight". It may have a little grind as the planetary gears go into mesh. sam Also have you removed the clevis pin on the actuator and moved the lever by hand should move easy Last edited by big job; 06-25-2019 at 08:28 AM. |
06-25-2019, 11:49 AM | #9 |
Could the hoses on the firewall valve be reversed now after the engine swap
06-25-2019, 08:52 PM | #10 |
I'll try this this weekend. I had a gauge on the valve and it went to zero when I went to low. Seemed to react pretty well from vacuum to zero. I don't think its the valve. I haven't tried disengaging the actuator from the arm. I'll see if it moves more without the pin in. Good thought. Maybe it stiffened up from sitting this winter. I know I did.
I traced the hoses and everything looks good. It shifts up fine, so I think they are on correctly. |
06-30-2019, 05:20 PM | #11 |
OK I tried all the suggestions-nothing worked. I added a helper spring to the arm and that didn't help. Then my son suggested changing the gear lube in the diff. Guess what - there wasn't any in there. I added a gallon and off I went. shifted high to low no problem 4 times. Then it stopped. Pulled the filler plug and I cant feel the oil. Need to get more apparently. Looks like the rear was dry and couldn't make the shift. Maybe a solution is nearby.
07-01-2019, 05:34 PM | #12 |
so, if it shifts by itself while we are all sleeping, doesnt that make it possible to not complete the shift, no gears engaged, and roll into the neighbors house?
07-01-2019, 07:27 PM | #13 |
Yes it does. That's why I chock the wheels. You would think it would be stuck between gears, but it doesn't. It always drops into low overnight.
I filled the diff all the way up with another 1/2 gallon and took it for a spin. No low range again.......... Frustrating to say the least..... |
07-02-2019, 05:08 AM | #14 |
Of all things we can not find the shop manual I has to be here-I don't lose books. Now
its looks like something internal as it is creeping into low overnight? How long it ran with no oil could be a factor. I guess next would be to take the arm and housing off and see how easy the part the shift arm goes into slides easy back and forth. My parts book shows no rocket science for this; Something has to be binding I highly doubt its rust? Something turned to dried mud cause my thinking says high is under power and low is under spring power thats not enough for something gummed up. Meanwhile I'll keep digging I been wrenching on these since they built our highways this is a first !! Also even running without oil, first thing that will go is pinion bearings NOT the planetary gear set cause its either in or out and is locked to the ring gear. sam |
