Old 06-26-2020, 05:27 PM   #1
aermotor
Default steering adjustment
Can the 4th adjustment be made with the steering box in the car if the column clamp is loose and maybe lifting the column with the horn rod released? (Two tooth box)
John
aermotor is offline   Reply With Quote
Old 06-27-2020, 06:53 AM   #2
tinkirk
tinkirk's Avatar
Default Re: steering adjustment
Yes
tinkirk is offline   Reply With Quote
Old 06-27-2020, 07:22 AM   #3
old31
Yes, but you do not have to lift or loosen the column or take apart the horn rod.
old31 is offline   Reply With Quote
Old 06-27-2020, 07:52 AM   #4
Patrick L.
Patrick L.'s Avatar
Yep. You'll need to bend a screwdriver to get at it. At least I did. Part of owning an old car is having to 'warp' or make tools to work.
Old 06-27-2020, 09:47 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
You can buy one of these to make the sector axial play adjustment in the car.
Bob Bidonde
Old 06-27-2020, 12:24 PM   #6
Patrick L.
Patrick L.'s Avatar
I can remember when everyone said the box had to come out to check/set the 4th adjustment.
Old 06-27-2020, 03:31 PM   #7
burner31
burner31's Avatar
You are correct:
But that was before a farmer said "Here boy, hold my beer and watch this"
Keith
Shawnee OK
'31 SW 160-B
Old 06-27-2020, 07:38 PM   #8
Patrick L.
Patrick L.'s Avatar
Originally Posted by burner31 View Post
You are correct:
I happen to like beer. Some folks said that couldn't be done after I mentioned it can. I still like beer and they are welcome to watch.
