Old 08-14-2020, 07:48 PM   #1
v8fordman
v8fordman's Avatar
Default Aristocrat Dash Panel?
I found this in my dad's Model A "stuff". I am wondering if this is an Aristocrat accessory aftermarket dash? It is all aluminum.
v8fordman is offline   Reply With Quote
Old 08-14-2020, 09:31 PM   #2
Brian SATX
Brian SATX's Avatar
Default Re: Aristocrat Dash Panel?
Not sure of he brand but yes it is like an Aristocrat.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 08-14-2020, 10:53 PM   #3
A 2 B
A 2 B's Avatar
Yes, that is an Aristocrat. The very early ones were said to be made from steel but I've never seen one. I have one like yours that was in a '30 coupe hot rod project I bought. They were discontinued only a few years ago.
A 2 B is offline   Reply With Quote
Old 08-15-2020, 06:37 AM   #4
DBSHELTON
I sure wish someone would repop these!! I would love a couple of them.
DBSHELTON is offline   Reply With Quote
Old 08-15-2020, 06:41 AM   #5
David R.
What do you put in the extra holes?
David R. is offline   Reply With Quote
Old 08-15-2020, 06:47 AM   #6
DBSHELTON
Oil pressure, temp gauges?
Old 08-15-2020, 08:33 AM   #7
v8fordman
v8fordman's Avatar
That was going to be my next question. Would old Stewart Warner gauges fit the holes?
Old 08-15-2020, 08:41 AM   #8
Jack Shaft
Oil pressure gauge in a gravity system?nothing like the confident feeling of 2 pounds on the gauge..rather that be a mystery looks like the ammeter hole was hacked open..
Old 08-15-2020, 08:59 AM   #9
rotorwrench
rotorwrench's Avatar
Some of these types of accessories were being made when folks were installing V8 engines. They were the early aftermarket hot rod parts. They wouldn't be all that necessary on a stocker.
Old 08-15-2020, 10:33 AM   #10
A 2 B
A 2 B's Avatar
I don't have enough post to put up pics but the Aristocrat panel I have has a Speedo, top center in an enlarged hole, a SW volt meter, SW fuel gauge, two SW water temp gauges to accommodate the V8 flathead and a SW oil pressure gauge. Everyone thinks it looks rather unique, compact and well co-ordinated.
They were originally sold in 1932.
Old 08-15-2020, 10:48 AM   #11
Bob C
Here's a picture that was posted by Brad In Germany.
Old 08-15-2020, 12:26 PM   #12
Joop
Joop's Avatar
Nice 1930 AD
File Type: jpg 7A799CE0-E7E2-47D4-861A-2F5546F823A2.jpg (68.3 KB, 128 views)
Joop is offline   Reply With Quote
Old 08-15-2020, 02:32 PM   #13
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Actually, the "confidence" you receive is that you see the oil pump is actually working. In frigid temps back in the era with straight grade oils, it would peg the gauge during initial start up. Once the engine had some heat from idling, the gauge would no longer be pegged and at that point it was safe to begin driving your Model-A. Driving too soon with too thick of oil providing little lubrication and would burn-out the bearings.
As for the Ammeter hole hacked open, didn't these overlay the original instrument panel where the Ignition Switch, Ammeter, and Speedometer attach to that panel?? If so, it needed the clearance for the trim bezel on the Ammeter.
My dad grew up about 50 miles south of Clarinda, IA where these panels were manufactured, when I was 6 or 7 years old, we attended a farm sale just outside of town while we were vacationing at my grandparents. At that sale were 5 NOS Aristocrat panels, -and all but one panel had the gauges still in them. All I remember is there were 4 of one style and 1 of the other. Dad always told the story that he paid $20.00 for the whole lot and sold 4 of them for $100.00 a piece, -which he thought was big money back then. It paid for vacation that summer and then other A parts he needed. I would guess an NOS 1930-31 panel complete with the original Dunn script gauges would likely fetch north of $1500.00 these days.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-16-2020, 01:05 AM   #14
Brad in Germany
Brad in Germany's Avatar
Here are two variations of the original Aristocrat dash panels for the '30-'31 Model A's (note the area around the water temperature and oil gauges):
.....and a close up of the area showing the name of the manufacturer and the detail of the background pattern:
.....and this one with original Dunn gauges:
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 08-16-2020, 12:51 PM   #15
A 2 B
A 2 B's Avatar
A little off tangent but this is the panel that was reworked for a '30 coupe with a 8ba, having dual temp gauges and reading in KPH for use in Canada.
Old 08-16-2020, 01:29 PM   #16
Tim Ayers
Me too. I would pay to get on a waiting list if someone would. They use to be around, but have all seemed to have dried up.
Tim Ayers is online now   Reply With Quote
Old 08-16-2020, 04:47 PM   #17
Jack Shaft
Isn't that why you have a water temp gauge?to tell you when you reach operating temp?.Stop pumping flow into the valve gallery and you'll hear the valve clatter well before you ruin bearings..
Old 08-16-2020, 07:18 PM   #18
Licensed to kill
Licensed to kill's Avatar
I didn't know that solid lifters clattered from lack of oil. I know hydraulic lifters do but have no real experience with solid lifters and just assumed that they would not clatter from lack of oil if they are set properly. Good to know.
Licensed to kill is offline   Reply With Quote
Old 08-16-2020, 07:59 PM   #19
Jack Shaft
The entire valve train relies on lubrication mainly from splash.The valve gallery needs to be kept full to adequately lubricate the valve train,the main bearings will starve when the galley runs dry,being fed from tubes in the bottom of the gallery..
Old 08-16-2020, 08:11 PM   #20
Licensed to kill
I'm aware of all that. I just assumed that, since the valve lash doesn't change on solid lifters when starved for oil like a hydraulic lifter that they wouldn't chatter.
