Old 10-02-2013, 09:55 AM   #1
Mistilee
Default 1936 Ford Pickup
Can anyone help me locate a picture of what the spare tire bracket for a 1936 ford pickup looks like?
Does anyone have one for sale.
Thank You
Mistilee is offline   Reply With Quote
Old 10-02-2013, 10:55 AM   #2
Mike B
Default Re: 1936 Ford Pickup
Here ya go!
http://www.ebay.com/itm/1936-ford-pi...4c45c6&vxp=mtr
I notice the seller mentioned it came from a '37.
I'll take a look at mine later and see if it looks the same.
Mike B is offline   Reply With Quote
Old 10-02-2013, 11:58 AM   #3
Mike in AZ
Mike in AZ's Avatar
Lawson Cox should have some pics for ya....hopefully he'll chime in when he checks the 'Barn....and welcome to the 'Barn.....Mike
Mike in AZ is offline   Reply With Quote
Old 10-02-2013, 12:24 PM   #4
banjoQ
banjoQ's Avatar
Mine is like the one pictured in the ad but without the band over the top. The one pictured is for a 37'. This must have been a change after 36'. Probably an improvement as I have had to resort to using rope to tie mine in at the top.
banjoQ is offline   Reply With Quote
Old 10-02-2013, 07:20 PM   #5
37fordpickup
Looks just like mine . Mine doesn't have the band over the top to lock the tire on.
37fordpickup is offline   Reply With Quote
Old 10-02-2013, 07:40 PM   #6
Fe26
Welcome to the Barn. Be aware that when you tighten your spare wheel onto your new bracket there is a lot of play in the wheel, this is annoying but normal.
Fe26 is offline   Reply With Quote
Old 10-02-2013, 09:01 PM   #7
Lawson Cox
Lawson Cox's Avatar
I have several pictures and a factory drawing, but I have a new computer and cannot seem to be able to pull one up. I'll keep working on it.
Old 10-03-2013, 09:27 AM   #8
36tbird
I have one from my '36 pickup. PM me with your e-mail address so that I can send you pics if you like.
36tbird is offline   Reply With Quote
Old 10-03-2013, 09:48 AM   #9
Mistilee
Thank you, I appreciate your time and help.
[email protected]
Old 10-03-2013, 09:50 AM   #10
Mistilee
Originally Posted by Mike B View Post
Here ya go!
Thank you for all your help is there 3 holes that are in the running board that the bracket mounts to? I am under the impression it does not mount to the bed
Old 10-03-2013, 09:51 AM   #11
Mistilee
Thank You I appreciate all the help I can get!
Old 10-03-2013, 09:52 AM   #12
Mistilee
Thank you for your time an your help I appreciate it!
Old 10-03-2013, 09:54 AM   #13
Mistilee
Thank you for the information
Old 10-03-2013, 09:55 AM   #14
Mistilee
Thank You
Old 10-03-2013, 09:57 AM   #15
Mistilee
Thank You
Old 10-03-2013, 10:02 AM   #16
Mistilee
Here ya go!
Will it be a problem since it says that the upper threads have been cut off?
Old 10-03-2013, 02:42 PM   #17
36Bill
36Bill's Avatar
Check the swap meet section for early v8.
Bill
36Bill is offline   Reply With Quote
Old 10-05-2013, 10:16 AM   #18
36tbird
Sent you pics of the one I have to your e-mail address posted in this thread. Did you receive?
Old 10-06-2013, 06:10 AM   #19
oldandtired
I believe the 36 and 37 halfton pickups (and panel deliveries) used the same spare rod and spare flange. The top strap was used if you also had the frying pan like locking spare option on the pickup, otherwise there was no top strap.
The 35 spare rod is a one year rod and the 38/9 has two "eyes" in the middle rather than the one on the 36/7.
oldandtired is offline   Reply With Quote
Old 10-06-2013, 06:16 AM   #20
oldandtired
The one posted on eBay has the top strap used with the locking spare as well as the mounting flange. It also has the small brace like bracket that helps support the barand the spacer. It appears that they cut the bolt that passes through the spacer, but that can be easily replaced. If the threads on the botton are good, and they appear to be because the nut is on it, you should have no problems with the one on eBay. The price is certainly reasonable...at the moment.
