08-31-2019, 02:48 PM | #21 |
Re: hidden radio ideas or just slighty out of sight. wood hide door?
Here is where mine is located. The speakers and antenna are under the headliner.
09-04-2019, 09:33 PM | #22 |
Well..when I decided to add a radio, this is what I ended up with. I use a small battery powered FM transmitter hooked up to an old iPod to play appropriate tunes - usually a selection of 1920s-1930s music.
09-05-2019, 07:50 PM | #23 |
I listen to Classic country on my truck radio all the time and I am 79. Don't listen to all this Rap Crap at all or modern Rock.
09-05-2019, 07:55 PM | #24 |
That looks like a good idea to me. Gonna be faced with the radio situation as I get closer to the end of the Restoration of our 1946 Ford Super Deluxe Coupe Sedan. But I know someone that converts old radios to 12 volt or leave it at 6 volts, to AM or FM I have a stock 46 Ford radio that doesn't work as far as I know.
09-05-2019, 10:32 PM | #25 | |
Sent from my E6810 using Tapatalk |
09-06-2019, 01:05 AM | #26 |
09-06-2019, 08:30 AM | #27 |
bwhaha hardy har har. I have made a box similar to Paul Mike's that I am mounting on the kick panel over my clutch foot. Made out of some 3/4 that I sprayed with black spray paint. I dont have it attached yet But I think it will hide well. Its one of those spots where its just too hard to get a look at unless your looking right at it. I will get it attached and get a photo soon. Im thinking of putting my speakers in a old tool box and have that behind the front seat in the rear foot well.
09-06-2019, 02:51 PM | #28 |
here is the box Its rough I didn't spend much time on it may clean it up later.
09-30-2019, 04:20 AM | #29 |
Here's a draft of the MP3 player. Currently the broken folder skip buttons (folder skip wasn't co-operating with me) is set to jump the tracks ahead by 5 or so, sometimes more if you've pressed "skip track" a few times. Add to the coding with the arrows to expand how many songs you can skip. I haven't written anything to re-set the counter to zero once you'd skipped all the way to the end. But with 100 albums worth it think that'll take a while. i'll let you know if i make it bluetooth compatible but i see a straight bluetooth module that connects with almost no effort at all...
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable Last edited by dumb person; 10-10-2019 at 09:41 PM. |
09-30-2019, 11:40 AM | #30 |
The docs I read for the Arduino show VCC as 3V input, RAW is for 5V. DFPlayer needs a ground. Just nitpicking.
If your car is negative ground you could use a 7805 connected to RAW and I'm guessing there would be a 3.3V output at VCC with which to power the player module. My 2 cts. |
09-30-2019, 11:03 PM | #31 |
Yeah i forgot to draw the ground. The 3.3 volt at VCC doesn't have enough grunt to run the MP3 though. I tried it. 3.6-4 volts runs it happily though.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
10-10-2019, 09:43 PM | #32 |
Updated the software side for better auto-play. Won't stop playing at track 127 without being prompted to play the next now.
(although the work around i used is barbaric in my eyes)
10-12-2019, 12:18 PM | #33 |
Ahooga Around the World |
11-19-2019, 11:12 AM | #34 |
I just got back to the radio project. I made this hide box for the speakers. I haven't figured out how I will attach it yet. maybe a few blocks screwed to floor then a screw through the side of the box. I spent a few frustrating hours resizing the box. It was an old crate that was holding some parts I got a while back. shrunk it about half. the other thing that was frustrating was this box would have been assembled wet and I had to be very careful to not crack it all apart. I should have wet it down first. I had to rinse it and rub it down after blackening it with a blow torch. It will sit behind my seats. The rear footwell in fordors is huge. these are 3 way pioneer 6x9 that I got on ebay for 35 for the pair. the box is the size a large shoe box. I had to do a bunch of ugly cutting with snips on the plastic surrounding the grilles. didn't account fully for them when sizing the box. But then wanted to use them to prevent debris from getting in the speaker cones.
11-19-2019, 11:18 AM | #35 |
I dont plan on blasting the tunes. But think these speakers should give a clean sound at low volume.
11-20-2019, 11:13 AM | #36 |
The only thing..... you can't hear what your "A" is telling you.
11-20-2019, 07:33 PM | #37 |
I put a am fm radio, cd player in my big 29 AA, I removed the letter pouch and made one larger, bought a hidden antenna on ebay $17,00, I use resister plugs with no static, bought 2- 4" diameter speakers on ebay $28.00.
carry on |
