05-31-2023, 09:34 AM | #1 |
12volt Conversion 45 Ford 1/2 Ton Pickup
Hi all,
I’m converting to a 12volt system from Vintage Auto Garage. I’m try to find out where some of you picked up Power of an electronic fuel pump and the voltage relay 12v to 6v. The directions say, “ connect to switched 12-volt power, such as ignition switch ACC or Ignition Terminal. I was thinking of taking it from the ignition switch on the way to the coil.
Thanks, Will “1Tim 3:16 And without controversy great is the mystery of godliness: God was manifest in the flesh, justified in the Spirit, seen of angels, preached unto the Gentiles, believed on in the world, received up into glory.” |
05-31-2023, 01:54 PM | #2 |
Re: 12volt Conversion 45 Ford 1/2 Ton Pickup
Take the power from the circuit breaker battery terminal. Add a fuse to that power line to the relay. And I put the trigger wire on the gauges terminal of the ignition switch although I don’t think it matters which switched terminal you choose.
I found the late JSeery’s diagrams helpful. I don’t have his 12v diagram saved however. Search for his posts, and you’ll find it.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
05-31-2023, 10:16 PM | #3 |
Thank you so much that make great sense. I’ll look for the diagrams.
“And without controversy great is the mystery of godliness: God was manifest in the flesh, justified in the Spirit, seen of angels, preached unto the Gentiles, believed on in the world, received up into glory.” www.jalopyjournal.netwww.jalopyjournal.net1 Timothy www.jalopyjournal.net3:www.jalopyjournal.net16
05-31-2023, 10:55 PM | #4 |
What size fuse would you go with I’d seen 10am am]nd 30 amp discussions?
06-01-2023, 11:08 PM | #5 |
I used his diagrams for my headlights and fuel pump. He made good diagrams. My pickup is 6v positive ground. I can’t find a fuel pump relay diagram for 12v from him, but here is his 12v headlight relay diagram. For 12v looks like he used a 15 amp fuse on 14 gauge wire.
Check out his info and diagrams in these posts: https://www.fordbarn.com/forum/showt...7593&showall=1 https://www.fordbarn.com/forum/showthread.php?t=145271 And when Bob Dylan was playing only Christian songs in 1980, there’s a recording of him quoting your verse before one of his songs.
06-02-2023, 12:09 AM | #6 | |
06-02-2023, 07:17 AM | #7 |
Use a separate switch for the Fuel Pump in case of an emergency. There are other safety measures but this is the easiest.
06-02-2023, 10:22 AM | #8 |
Thanks, for sure, it came with the kit. I believe I have it… it would be great it see a video of the placement of wiring and fuses. I’m a visual learner. I’ll look on YouTube they my have I video.
Thanks again.
06-03-2023, 04:46 PM | #9 |
I’m adding a fuse block! I have another question from the vintage auto garage conversion kit. Now the relay for the headlights. Looks like the same relay for the horn. Am I supposed to wire the horn to the same relay as the headlights or was I supposed to get two relays? I only got one relay.
Also, the fuel pump is in fused and ready. Thank you all for the help.
06-03-2023, 10:34 PM | #10 |
Definitely separate relays for horn and headlights.
There is a good headlight wiring diagram in those posts I copied above from Jseery. And the headlights ideally would have one relay for the low beams and one relay for the high beams. Totaling 2 relays for the headlights.
06-04-2023, 02:20 PM | #11 |
Great thank you. I thought so.
