Old 05-30-2019, 04:26 PM   #1
wbs
Default shock absorbers
hello -my 24 touring has "australian" shock aborbers per march 23, 2013 string by andre valkenaers on model t forum. i'm going to try post a picture but if i fail , there is a pictrure in the post. my question is: how do i lube the shackle? i can't find any lube point, thanks-------also some of the other oil points wth the caps are missing -i can't find these items in snyders--who sells them and are they just press in?
wbs is offline   Reply With Quote
Old 05-30-2019, 06:19 PM   #2
Dodge
Default Re: shock absorbers
In a Model T the passengers are the shock absorbers....
Dodge is offline   Reply With Quote
Old 05-31-2019, 01:43 PM   #3
redmodelt
redmodelt's Avatar
Here you go;
https://www.snydersantiqueauto.com/P...earchByKeyword
You can also buy them by the each and yes they press in.
There should be holes in the top of the bottom leaf and perches for oil. ?They may just be plugged with paint or dirt. If your car has a mix of parts or is earlier it would be different. Maybe post a few photos of what you are working with. After this many years who knows what has been changed around.
Can you post a link to Andre's shocks? Not sure what "Australian" socks are.
Old 06-03-2019, 07:53 AM   #4
wbs
thanks for reply--link to shock absorbers and picture
http://www.mtfca.com/discus/messages...tml?1364537010
also are there any T owners living near Little Switzerland, NC ? my friend there is a new T owner and needs help learning to drive T
