03-20-2016, 05:21 PM | #1 |
Fitting 1934 differential in 1932
I know of a person with a
1932 Ford Tudor and he wants to fit a 1934 Ford V8 Differential into it and he would like to know how much you would shorten the drive shaft to make it fit. |
03-20-2016, 05:27 PM | #2 |
Re: Fitting 1934 differential in 1932
8 9/16"
03-21-2016, 03:38 PM | #3 |
03-21-2016, 04:23 PM | #4 |
Torque tube will have to be shortened the same also
03-21-2016, 11:00 PM | #5 |
Are the '32 banjo housing the same diameter as the '34?
03-21-2016, 11:22 PM | #6 |
03-22-2016, 02:33 AM | #7 |
The easily spotted identifier for the early axles is that the radius arms bolt to the axle tubes on a couple of brackets. (not big ones like 35-36). The brackets are straight to the car center line on 32s and in line with the radius arms on the 33/34.
Mart. |
