05-08-2017, 09:16 PM | #1 |
Idle RPM
Is there a good idle rpm range? I have a clamp-on tach to check.
05-08-2017, 09:27 PM | #2 |
Re: Idle RPM
I've never had a tach. on my '31 so I do not know.
I set it where I can hear the individual cylinders firing so I am guessing 400 RPM more or less...... |
05-08-2017, 11:58 PM | #3 |
Re: Idle RPM
500 (or so) works for me.
05-09-2017, 12:01 AM | #4 |
Re: Idle RPM
Since I have never had a tach on mine, I just adjust the idle screw til it quits and back it out ½ turn.
05-09-2017, 02:29 AM | #5 |
Re: Idle RPM
I reckon that anything less than 500rpm is within OK range. After a rebuilding of a carb I generally get them happy at 390-450 rpm but all cars are different
05-09-2017, 06:19 AM | #6 |
Re: Idle RPM
05-09-2017, 06:53 AM | #7 |
Re: Idle RPM
05-09-2017, 09:07 AM | #8 |
Re: Idle RPM
You can use a digital tach that has a RPM scale. Not sure if they work on 6 V. but almost everybody has a jump box that will power it.
05-09-2017, 10:07 AM | #9 |
Re: Idle RPM
I have a hand held " EZ Tach Digital" powered by a 9v battery. Works great on 2 or 4 stroke cycles, cars, etc. Not sure though how it will work on the A leads from distrib to plugs with auto advance FS ignition...
05-09-2017, 10:26 AM | #10 |
Re: Idle RPM
cheapo tachos available via ebay . They work by having their pickup wire adjacent to HT lead. Does not look period as digital and plastic but reasonably accurate against an old analogue ( do you guys spell it analog?) one. Unless their both wrong of course.?
05-10-2017, 12:07 AM | #11 |
Re: Idle RPM
