08-10-2022, 04:24 PM | #21 |
Re: Burtz Block
Originally Posted by BRENT in 10-uh-C View Post So allow me ask a question regarding thicknesses, ....would you rather buy a new set of tires that has 10/32" of tread depth, -or tires with 3/32" of tread depth?? It seems like someone would get 3X more mileage when they start with the 10/32" depth tires. So if the same thought was applied to Model-A engine bearings, wouldn't someone get 3X more longevity out of a babbitted engine over a inserted engine if the same quality of bearing materials was used, and all mechanical parts were of equal specification and condition?? No. The thicker the Babbitt the more compressable it is, the more it compresses the more it fatigues and starts cracking and falling out. That is why High performance and race engines use Tri-metal bearings. Tri-metal bearings have a steel back , copper underlay to support the thin layer of Tin/Babbitt. The copper underlay is not nearly as compressable as Babbitt and as a result less fatigue and longer bearing life. Bill PS Read up on Clevite 77 bearings. Bill, Your answer to Brent's question is correct. Thank you. The new engine uses 12 pairs of Clevite CB-745P standard size tri-metal bearings. For those that want to learn about modern bearings, please see: Clevite “Light Vehicle Engine Bearings” catalog EB-20-18 (https://www.mahle-aftermarket.com/me...s/eb-20-18.pdf) |
08-10-2022, 04:57 PM | #22 | |
Re: Burtz Block
Most rebuilders today use WAY more shims (-i.e.: thickness) than what Ford used originally, and many rebuilders fail to peen the freshly cast metal for the purpose of compacting it simply because they don't know to do that, -or it is an effort to save time. Burnishing also falls into this category. As you correctly stated, this often causes fatigue & cracks in the bearing. When the proper composition of babbitt is used, and when process is done correctly, the additional compaction, fatigue, and cracking is not seen. As we have discussed above, engines with nearly triple the compression ratios have utilized poured and cast bearings with many years of great service to their credit. In the scenario of using an insert bearing that has the same compaction as the cast bearing, the wear should be the same with little to no difference between the two types of bearings, HOWEVER when the babbitt on the insert shell has worn 0.002", that bearing is reached the end of its' life cycle whereas the cast bearing has the ability to remove one or both shims and continue many more miles. |
08-10-2022, 05:10 PM | #23 | |
Re: Burtz Block
Bill |
08-10-2022, 05:12 PM | #24 |
Re: Burtz Block
From the reference listed by Terry above, Bearing life versus Babbett thickness. Even though the bearing life is maximum at minimum thickness, some thickness is needed for various reasons.
What the graph shows is that an insert bearing will last 10 times as long as poured bearings (250 vs. 25). (Depending on how you read the graph it could be 8 times as long, but still longer.) Also, based on my experience on various engines, when the insert bearings need replacing, the journal is normally still good and new insert bearings can just be installed. What the reference also says, in so many words, is that an oil filter is important to have. And that proper assembly is very important.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-10-2022 at 05:37 PM. |
08-10-2022, 05:41 PM | #25 | |
Re: Burtz Block
Brent, I agree with some of what you say, but believe that your reply is directed to the comments made by Bill, not me. Please keep in mind that the inherent design problem in a Model A engine is the flexible and under-supported crankshaft. Insert bearings are not new. The Dodge "Fast 4" engine built in 1927 and 1928 was a 4 cylinder, 5 main bearing design that used Federal-Mogul insert 6345B for the connecting rods and Federal-Mogul main bearing set 277M. Terry Burtz |
08-10-2022, 05:50 PM | #26 | |
Re: Burtz Block
Neil, Thanks for looking at the Clevite catalog and displaying the graph. Sometimes thicker is not better and results in a shorter life. |
08-10-2022, 07:21 PM | #27 | |
Re: Burtz Block
Agreed on your comments re compression readings. The figure I quoted was after your 4 or so cycles so maybe the true number is not so high. On another matter, have you had experience with the rear (inserted) main bearing starving for oil? I have seen a couple of examples of the insert being pretty chewed up. Fortunately, the journal was OK and a new insert was all it took. Before fitting them, I cut a spiral groove in he top insert to get oil towards the back of the bearing. I stopped the groove about 10mm (3/8") from the edge of it. I run 20w50 grade oil and I'm thinking that something like 15w40 might be better. Watchya reckon?
08-10-2022, 08:25 PM | #28 |
Re: Burtz Block
Guys this is giving me tons of info I really appreciate all of this
Thanks again Dave |
08-10-2022, 08:39 PM | #29 |
Re: Burtz Block
Terry is your engine fully pressurized?
08-10-2022, 09:25 PM | #30 |
Re: Burtz Block
Jack,
Yes, the "New Engine" has 17 pressure-fed bearings and all oil passages are drilled in cast iron bosses. There are no fittings or loose oil tubes. The 17 pressurized bearings include 5 main bearings, 5 camshaft bearings, the rear main thrust bearing, 4 connecting rod bearings, the camshaft thrust bearing at the front of the cylinder block, and the camshaft plunger thrust surface. More details can be found at www.modelaengine.com, www.burtzblock.com, and https://www.facebook.com/groups/1123377268114692 This thread has opened a can of worms with those that believe in the original thick-poured Babbitt bearing design with a flexible crankshaft and those that understand modern engine design. Last edited by Terry Burtz, Calif; 08-10-2022 at 09:36 PM. Reason: Spelling |
08-10-2022, 10:21 PM | #31 | |
Re: Burtz Block
I believe in the superiority of your block and internal improvements. |
08-10-2022, 11:53 PM | #32 | |
Re: Burtz Block
08-11-2022, 02:14 AM | #33 |
Re: Burtz Block
I don't know how many babbitt motors have gone 400,000 miles but I know of several
insert bearing motors that have.... |
08-11-2022, 06:44 AM | #34 | |
Re: Burtz Block
That said, 400,000 miles is chicken feed for a decent truck engine many of which have (as has been said) Babbit bearings.
08-11-2022, 07:13 AM | #35 |
Re: Burtz Block
Full pressurization is the key for insert bearings, it keeps them clean and cool.My observations about insert and babbit bearings was predicated on the stock A splash and gravity method of lubricating rod and main bearings.
08-11-2022, 08:36 AM | #36 |
Re: Burtz Block
Synchro, Just curious. What modern truck engines have poured bearings? I assume you meant poured bearings. Or do you mean antique truck engines? I know modern Diesel engines can go a million miles or more and I assume they are all insert bearings. Please contribute to my education.
By the way, there were some photos of cars in the 60's in Australia Surfer's Paradise recently in The Old Motor. https://theoldmotor.com/?p=191760
