10-27-2021, 06:55 AM | #21 |
Re: Tire Rotation
Here's a do it yourself tire balancing technique for the Model "A":
Bob Bidonde |
10-27-2021, 10:17 AM | #22 |
Re: Tire Rotation
[QUOTE=nkaminar;2070625What about the rears wearing faster than the fronts?[/QUOTE]
That's normal.
10-27-2021, 04:15 PM | #23 |
Re: Tire Rotation
My tires wear faster in the rear then the front. It's probably our driving habits. I think it is a good sign that your front alignment and suspension is in decent shape if there is less wear then the rear.
10-27-2021, 05:10 PM | #24 |
Re: Tire Rotation
Thank you all for your response. I have some radials on order and am anxiously awaiting their arrival. Just my imagination but it seems they are shipped by ox cart. I intend to balance using the method Bob showed. I have done this before with good results. Results depends on if the unbalance is in a plane or a dynamic unbalance. Driving the car will answer the question.
10-27-2021, 05:13 PM | #25 |
Re: Tire Rotation
10-27-2021, 08:10 PM | #26 | |
Re: Tire Rotation
Filled it with the beads and vibrated it by putting this sander next to the tube and watched them flow into the tube. Took maybe 10 minutes per tire. https://www.harborfreight.com/2-amp-...4aAsaAEALw_wcB Last edited by GPierce; 10-28-2021 at 03:10 PM. |
10-27-2021, 09:48 PM | #27 | |
Re: Tire Rotation
I have had wheels I have balanced this way up to about 100 Kph (60+mph) with absolutely no sign of vibration. That's enough for me.
10-28-2021, 05:47 AM | #28 |
Re: Tire Rotation
Here's a do it yourself tire balancing technique for the Model "A" - from Bob Bidonde |
10-29-2021, 09:42 AM | #29 |
Re: Tire Rotation
When just rotating 4 tires, just X them.
Always leaving radial tires one the same side has now become an old wives tale. True at one time but no longer. Balancing them is the same as any other vehicle. I put them on the spin balancer and mount the weights on the inside. |
10-29-2021, 07:02 PM | #30 | |
Re: Tire Rotation
I have always heard bias tires get crossed and radials stay on same side. This comes from my service station days of the 70s. |
10-31-2021, 03:08 PM | #31 |
Re: Tire Rotation
The powered tires typically wear quicker, unless the alignment is off, then that will cut tires very quickly.
10-31-2021, 03:24 PM | #32 |
Re: Tire Rotation
I balanced the wheels/tires as Merc Man outlined. However I noticed that the hub with brake drum was rotating on its own. I stuck 1.5 ounces of weights on the drum to balance it, equivalent to 3/4 ounce at the wheel rim.
So, even with perfectly balanced wheels they could still be out of balance if the drums are not balanced. I seem to remember steel weights spot welded to brake drums in the past. The stick on weights will not stay on the drum so they got removed. So the wheel on that corner is 3/4 ounce out of balance. I drove the car and did not notice it.
