11-24-2010, 11:32 PM | #1 |
Flasher Beeper
Hi,
Could someone please advise me how to connnect a beeper to a 6 volt flasher with the X-Power L - Load P - Pilot flasher setup? I intend to install an electronic flasher to permit my LED taillites to work, but I would like to have the beeper function when activated. Thanks. |
11-25-2010, 12:09 AM | #2 |
Re: Flasher Beeper
11-25-2010, 06:29 AM | #3 |
Re: Flasher Beeper
were can you get a beeper for the turn signal.
11-25-2010, 06:34 AM | #4 |
Re: Flasher Beeper
Your local Radio Shack has them. Bruce
11-25-2010, 09:27 AM | #5 |
Re: Flasher Beeper THANK YOU MIKE K
Thank you, Mike K !
This answers my question completely. HAPPY THANKSGIBING TO ALL ! Bruce A. Northport, NY |
11-25-2010, 10:40 AM | #6 |
Re: Flasher Beeper
chirping loudly----kinda neat, JMHO. Jack
Cincinnati, Ohio |
11-25-2010, 10:54 AM | #7 |
Re: Flasher Beeper
Thanks Mike for the knowledge. I installed an additional buzzer in parallel with the existing built-in buzzer in the siginal light unit. Wife complains that it is too loud. Have to wire in a light instead. Will the same connections used for the buzzer work for the light ?
11-25-2010, 11:11 AM | #8 |
Re: Flasher Beeper
I have used the beepers from Radio Shack.About $3.and they are LOUD.However,you can regulate the noise level by putting a piece of tape over the hole the sound comes out.Covering half the hole truly gives you half the sound.I experimented until I got what I wanted in an MGTD kitcar.Those beepers were not polarity sensitive,and marked 3 to 28 volts.I had to use two as my car had been wired with a two prong flasher in the power line,with no pilot light.So I used two in the outgoing wires.
11-25-2010, 12:24 PM | #9 | |
Re: Flasher Beeper
Thread Tools | |
Display Modes | |
