04-29-2017, 08:31 PM | #1 |
what is missing part?
hello-i've tried to attach a photo of the front area of drive shaft- there are sockets on the sides to receive some kind of a ball type fitting on the riight and left. the part that should attach is missing. can any one tell me what the missing part would be.
pls see the attached photo. i hope it sends o.k. |
04-29-2017, 08:45 PM | #2 |
Re: what is missing part?
At the front of the torque tube, right behind the speedo gear attachment spot is the boss for the radius rods to bolt to, the left side of this picture.
04-29-2017, 08:55 PM | #3 | |
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
04-29-2017, 09:00 PM | #4 |
There are some pictures in post 13 and 14 of this thread....
https://www.fordbarn.com/forum/showthread.php?t=61920
04-29-2017, 11:54 PM | #5 |
I have all the parts you need to hook to the sockets. I just removed them from my car. Call Don in Visalia California at 559 786 0678.
04-30-2017, 08:02 AM | #6 |
04-30-2017, 11:38 AM | #7 |
Your's is fairly early, as my 28 has an engine number A404378 and tank date 9-27-28.
My car also has the split brake linkage, as the single bar didn't start until November 1928. |
04-30-2017, 08:43 PM | #8 |
If the car is a late 28 and is fitted with a full width brake cross shaft you can choose to ignore the universal ball cap and leave it as is. No harm will come of it. It may be as simple as someone fitting an incorrect ball cap over the years. Finding a correct late 28 ball cap should be quite easy if you wish to bring it back to original.
If you are going for a points restoration and it is in fact an early 28 then yes, you will have to find the correct two piece cross shafts, a dog bone connector etc. The early 28 used only one brake shoe in the rear hubs. The service brake and the emergency brake both operated the same brake shoe.
Adjust your points with gentle blows of a 2 pound hammer |
05-01-2017, 07:47 PM | #9 |
thanks to all- always an education
05-01-2017, 07:52 PM | #10 |
Here is the split linkage listed on ebay.......
http://www.ebay.com/itm/1928-AR-FORD...BY~m-l&vxp=mtr
