Old 04-12-2018, 11:10 AM   #1
Jamie L
Default Front Motor Mount Adjustment
How tight should the center bottom nut be on the front motor mount yoke be? Should it compress the springs? Just tight enough to get the cotter pin in the castle nut?
Jamie L is offline   Reply With Quote
Old 04-12-2018, 11:51 AM   #2
1955cj5
1955cj5's Avatar
Default Re: Front Motor Mound Adjustment
I found on my ccpu that if the spring was overly compressed there was more noticeable vibration, especially on deceleration.
I would go with the "just tight enough to get the cotter pin in...."
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-12-2018, 12:10 PM   #3
Jamie L
Thanks!
Old 04-12-2018, 12:20 PM   #4
1955cj5
1955cj5's Avatar
Default Re: Front Motor Mount Adjustment
Welcome to The Barn!
Which Model A do you have?
Old 04-12-2018, 12:55 PM   #5
SeaSlugs
SeaSlugs's Avatar
Yup just tight enough to slip cotter in.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-13-2018, 10:03 AM   #6
redmodelt
redmodelt's Avatar
Never mind, sorry I was thinking of something else.
Old 04-13-2018, 10:40 AM   #7
Kahuna
Kahuna's Avatar
Funny Red, I never heard it called Cotter.
Learn something new every day. LOL
Kahuna is offline   Reply With Quote
Old 04-13-2018, 06:31 PM   #8
Synchro909
They're actually a split pin! Cotter pins are an entirely different thing.
Procrastinate now. Don't put it off!
Old 04-13-2018, 06:37 PM   #9
1955cj5
1955cj5's Avatar
Uncle google knows...
cot·ter pin
ˈkädər ˌpin
noun
noun: cotter pin; plural noun: cotter pins; noun: cotter; plural noun: cotters
a metal pin used to fasten two parts of a mechanism together.
a split pin that is opened out after being passed through a hole.
Old 04-13-2018, 10:55 PM   #10
SeaSlugs
SeaSlugs's Avatar
Yea well its a cotter pin round these parts :P
Old 04-14-2018, 04:10 PM   #11
imacrazy
It's been a cotter pin all of my 82years.
imacrazy is offline   Reply With Quote
Old 04-14-2018, 05:27 PM   #12
Synchro909
Only 82 years! Heck, people believed he earth was flat for centuries. Refer to 1955's post.
Old 04-15-2018, 06:05 PM   #13
Jeff in BC
Jeff in BC's Avatar
They have been called "cotter pins" for at least 133 years. Before I was born!
Jeff
Jeff in BC is offline   Reply With Quote
Old 04-15-2018, 06:51 PM   #14
Synchro909
You guys have changed the terminology of a few things over the years. When did the ring gear move from the flywheel to the diff? I don't know how these things happen but they do - evolution?
Old 04-15-2018, 07:32 PM   #15
kimeccles
Well it is "really" a cotter key where I come from...
engine/frame # late May1930, Briggs body actual build date # indicates late Aug/Sept. 1930 68B fixed seat Cabriolet
kimeccles is offline   Reply With Quote
Old 04-15-2018, 07:44 PM   #16
160B
160B's Avatar
Here is another USA patent for a Cotter pin.
I have never seen one of these.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-15-2018, 07:47 PM   #17
kimeccles
The Cotter Key was invented by an Irish man named John Cotter in 1922. Originally used to hold fastners together on cabinets, Cotter keys found other purposes that seemed to be better suited than for that reason, such as, holding the Nuts on a bolt.
Thread Tools
Display Modes
