Old 06-14-2018, 04:49 PM   #1
wrndln
Default Oversize stop light brake clevis pin
Does anyone know if oversize stop light brake clevis pins are sold by anyone like the oversized regular clevis pins? This is the pin used on 28/29 brake pedals that has the deal on the end to hold the link to the brake light switch. I have some slop in the brake pedal hole using a standard clevis pin. I guess I could weld it up and redrill the hole to the proper size, but the pedal is already painted. I haven't seen any oversized pins, but maybe someone sells them.
Rusty Nelson
Old 06-14-2018, 08:52 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Oversize stop light brake clevis pin
Wouldnt be too hard for one to make out of a grade 8 bolt and a lathe if you got the right oversize dimension. Got a buddy with a lathe?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-15-2018, 05:28 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Hobby shop and hardware stores have thin wall brass tube that can be used to make a bushing.
Old 06-15-2018, 05:59 AM   #4
Patrick L.
Patrick L.'s Avatar
I would think about any hardware store would have a pin in a size that can be made to fit. Just drill the clevis to fit.
Old 06-15-2018, 07:02 AM   #5
wrndln
I don't have a lathe, but Tom's thin wall brass tubing sounds interesting. I will see if I can find one.
Rusty Nelson
Old 06-15-2018, 08:43 AM   #6
Afordman31
Afordman31's Avatar
PM sent
Afordman31 is offline   Reply With Quote
Old 06-15-2018, 09:17 AM   #7
sofield
Simple solution, buy a new clevis & pin.
Sofield
sofield is offline   Reply With Quote
Old 06-15-2018, 09:23 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Sofield
OH, thet's TOO EASY---LOL
SA Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-15-2018, 10:09 AM   #9
Bob C
Sofield
That won't fix the brake pedal.
Bob
Old 06-15-2018, 11:36 AM   #10
wrndln
Bob C is correct and sofield is WRONG. If it were that simple, I wouldn't have posted a message. Try to buy a new brake pedal.
Rusty Nelson
Old 06-15-2018, 09:07 PM   #11
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I would think that a thin brass bushing wouldn’t last very long.
Old 06-16-2018, 01:33 AM   #12
SeaSlugs
SeaSlugs's Avatar
I wouldnt either...
PM sent to wrdln
Old 06-16-2018, 04:43 AM   #13
Patrick L.
Patrick L.'s Avatar
Rusty Nelson
You don't need a lathe to drill out a hole. I don't think you do anyway.
Old 06-16-2018, 12:49 PM   #14
J Franklin
J Franklin's Avatar
Weld and drill the hole to size, rattle can black is fast and easy to repaint the pedal.
