05-24-2016, 08:37 AM | #1 |
Need some help identifying
Gents, recently picked up a body and am having some trouble nailing down exactly what I have. All I have to go by is the serial plate on the firewall. Any help you could offer would be greatly appreciated. Thanks.
05-24-2016, 08:59 AM | #2 |
Re: Need some help identifying
Picture of the body would assist in any identification.
05-24-2016, 09:20 AM | #3 |
There's not much left of it as it's been chopped up, but I will see what I can get for you.
05-24-2016, 09:36 AM | #4 |
Serial plate is obviously crudely removed from something and crudely reattached here.
The "B" does not belong, leading me to suspect that the intent was to convert this into a phony '32 serial (wrong in every possible way historically, wrong in a felonious way legally). Is this heap being described as a '32 Ford?? Any way, the number is on the wrong vehicle and has been altered with the B. I think that's two felonies. |
05-24-2016, 09:52 AM | #5 |
Ditto on the felonies.
It is quite possible that the body tag is not original to what you have. Even if it were a '28 model A special coupe yours doesn't seem to have the same shape. Possible it's not even a Ford body.
05-24-2016, 10:13 AM | #6 | |
The vehicle, what clues there are, I'm not recognizing. There is not a whole lot left of whatever it started out as, but you knew that.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
05-24-2016, 11:27 AM | #7 |
Absolutely I know there's not a whole lot left. It seems that it was originally a t-bucket style rod that had the top added later. I'm not trying to win any shows or friends with this thing, I was just curious to the origin of the tag/body. Even without the B, I was just coming up short in some research. Figured I'd turn to some experts to maybe point me in the right direction. Thanks for the help anyways.
05-24-2016, 12:25 PM | #8 |
I think the tag is going to prove to be something from the '49-52 period, but that's a guess.
Whatever it is, it is a couple of decades newer than the body, is very crudely transplanted, and is altered. I think any encounter this car has with government is going to end very, very badly. I think the part damaged by the B would identify the type of Ford it came from. |
05-24-2016, 12:30 PM | #9 |
Cowl is 30-31 Ford, and the sides of the roof look like 28-29 Tudor sedan rear quarters to me.
05-24-2016, 02:04 PM | #10 |
Alchemy, Thank you. That's all I was after.
