Old 03-24-2016, 12:54 PM   #1
mrtexas
mrtexas's Avatar
Default What year are these Ford brakes with 11 inch drums?
http://www.ebay.com/itm/111946681964...84.m1555.l2649
mrtexas is offline   Reply With Quote
Old 03-24-2016, 02:01 PM   #2
slowforty
slowforty's Avatar
Default Re: What year are these Ford brakes with 11 inch drums?
could be early 50s Ford F-1 Pick-up Brakes
slowforty is offline   Reply With Quote
Old 03-24-2016, 02:35 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
'49-'51 Mercury also, but in this case '40 Ford.
Old 03-24-2016, 02:50 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 51 MERC-CT View Post
........ in this case '40 Ford.
'40 Ford? Are we looking at the same backing plates? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-24-2016, 02:58 PM   #5
Vic Piano
Vic Piano's Avatar
Those look like Bendix, not Lockheed brakes. Ford started using Bendix brakes on the F-1 Pickup in '48 and on cars in '49. The Zephyr used Bendix starting in '39.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 03-24-2016, 03:12 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Read the EBAY listing, that's what they came off of. That's why "in this case'
Old 03-24-2016, 03:17 PM   #7
rotorwrench
rotorwrench's Avatar
The drums might be F1 but it's harder to tell from the inside out. If they would have taken a photo of the outside I could tell a lot easier. A person usually has to take a bit of meat off the old spindles to get the backing plates to fit up to the earlier types.
Old 03-24-2016, 08:51 PM   #8
mrtexas
mrtexas's Avatar
The guy I bought them from said they came off a 1940. However they are not 1940 brakes as the drums are 11 inches and the brakes are bendix.
Old 03-25-2016, 04:18 AM   #9
rustynutz
They are not F1, The drum and hub are separate pieces on F1, looks like an early 60's style drum/hub.
rustynutz is offline   Reply With Quote
Old 03-25-2016, 04:32 AM   #10
19Fordy
19Fordy's Avatar
Just to clarify. Here's a pair of OEM 49-51 Merc front brakes. They are 11 in. dia. with 5 x 5 1/2 inch bolt pattern with removable drums as the drums slide over the studs and are "hub centered" with 3 little 1/4 inch bolts? I will check the dimensions of the spindle mounting bolt holes, if needed. Those shown on ebay don't match the Merc OEM so you can eliminate that possibility. I OSPHO'd them to keep Mr. Rust away. These are for sale if anyone needs them. Check For Sale section.
Old 03-25-2016, 06:01 AM   #11
oldbugger
oldbugger's Avatar
I have a 64 tbird with 11 inch brakes, looks a bit like those. Paul
oldbugger is offline   Reply With Quote
Old 03-25-2016, 08:50 AM   #12
TJ
TJ's Avatar
Could be 53-56 F-100. They can be adapted to the '40 spindle using an inner bearing and seal change. The seller indicates" they are later model gear" he removed from a 40.I've put the 53-56 F-100's on three different cars. They will work on spindles from 37-48.
Old 03-25-2016, 09:12 AM   #13
V12Bill
V12Bill's Avatar
Ford had 12" brakes from 39 to 48. Not familiar with later models. The Zephyr used 12" drums also.
V12Bill is offline   Reply With Quote
Old 03-25-2016, 10:12 AM   #14
flatjack9
flatjack9's Avatar
I have the F-1 brakes on my 39. Early f-100 brakes fit also. Avery common upgrade in braking.
Old 03-25-2016, 10:18 AM   #15
JSeery
JSeery's Avatar
I'm using F-1 on my 33, fairly simple upgrade. The mod I did required the F-1 hubs as well as backing plates. Used later model pickup drums. This was a front axle only modification, as I have 9 inch Ford axles in a 38 banjo rear axle (quickchange).
Old 04-02-2016, 02:31 PM   #16
rpu28
flatjack, I'm using what I believe to be F1 brakes on my '40 axle. However, the aftermarket drums I bought stick out too far because they are 11" x 2.5" and my brake shoes are only 2" wide. Are the F1 brakes supposed to be 2.5" and I have something else?
rpu28 is offline   Reply With Quote
Old 04-02-2016, 02:58 PM   #17
JSeery
JSeery's Avatar
They should be 2.0 inch. I may depend on what drums you have, if they are later model F-150 rear drums, they will be 2.5 inch wide. I run these drums on my 33 front axle with F1 backing plates and hubs. It ends up a 2.0 shoe on a 2.5 inch drum, I don't see a problem with this, but others might! It was a fairly common practice in the past.
Old 04-04-2016, 09:43 PM   #18
rich b
rich b's Avatar
If you bought 2.5" Bronco/F-100 rear drums, thinking you have F-1 hubs and they stuck out too far, maybe you have F-100 hubs. If that's the case F-100 drums are readily available from most any parts store.
rich b is offline   Reply With Quote
Thread Tools
Display Modes
